Hi-Flo "Street Killer" Install pics
Old 04-18-2007, 09:30 AM
52172's Avatar
Default Hi-Flo "Street Killer" Install pics
Here are some pics of my install. Car is at the shop getting finished. Progress is being made pretty slowly since every step comes another little problem. You can see we got the intercooler to stand upright unlike the way hi-flo was installing theirs. We need to fab a custom downpipe since the Hi-Flo one was not working. We are now working on routing the plug wires and installing gages. We still need to make swaybar spacers to clear the crossover. We are also going to make custom A/c lines and hook up the A/C. Car should be finished in two weeks or so. Work has been going on for two months so far. I will keep adding pics as they come.
Attached Thumbnails Hi-Flo "Street Killer" Install pics-img_0805-1-.jpg   Hi-Flo "Street Killer" Install pics-img_0806-2-.jpg   Hi-Flo "Street Killer" Install pics-img_0807-2-.jpg   Hi-Flo "Street Killer" Install pics-img_0808-1-.jpg   Hi-Flo "Street Killer" Install pics-img_0809-3-.jpg
Hi-Flo "Street Killer" Install pics-img_0811-4-.jpg   Hi-Flo "Street Killer" Install pics-img_0812-1-.jpg   Hi-Flo "Street Killer" Install pics-img_0814-3-.jpg   Hi-Flo "Street Killer" Install pics-img_0755-2-.jpg   Hi-Flo "Street Killer" Install pics-img_0756-2-.jpg
Old 04-18-2007, 09:38 AM
52172's Avatar
few more pics
Attached Thumbnails Hi-Flo "Street Killer" Install pics-img_0759-3-.jpg   Hi-Flo "Street Killer" Install pics-img_0760-1-.jpg   Hi-Flo "Street Killer" Install pics-img_0761-1-.jpg   Hi-Flo "Street Killer" Install pics-img_0763-2-.jpg   Hi-Flo "Street Killer" Install pics-img_0781-2-.jpg
Turbo LS1 SS's Avatar
looks good. make sure you look over the headers VERY closely. the welds were even shittier than i first thought. i had to weld shut NUMEROUS holes, and seams that werent welded in the first place. Not to mention milling the flanges at my buddy's work. also had to port the inside of the headers because someone doesnt know how to make headers, or weld thin SS properly.
what did it take to mount the IC vertical? im finally in the stages of putting my car back together, i had the chassis stripped down to nothing
Old 04-18-2007, 09:40 AM
52172's Avatar
Not sure what was involved mounting the intercooler upright the shop has been doing it, but I think they just did it like any other upright install. The same piping was used.
Old 04-18-2007, 09:42 AM
o rly? thats all i was worried about....the piping. i shall experiment today
Old 04-18-2007, 09:44 AM
52172's Avatar
Yea go for it.
smokinHawk's Avatar
whoa! why did you put the oil drain on the bottom of the pan? it needs to be above the oil level.
Old 04-18-2007, 09:51 AM
RealQuick's Avatar
nice catch on the oil drain smokin! Also, that wastegate was way off! Jeeze, it should never have left the shop like that!
Old 04-18-2007, 09:53 AM
52172's Avatar
Not sure why I just emailed the shop the ask that question? I will see what they say.
Old 04-18-2007, 09:55 AM
ABeasst's Avatar
yea definitely watch for holes in the welds. I also had to weld up holes. My wastegate dump tube was the same we had to finese it to make it fit.
Old 04-18-2007, 10:15 AM
52172's Avatar
Car never left the shop like that, but Hi-Flo did send the parts that were made like that. Hopefully a little finesse will make it fit.
Old 04-18-2007, 10:17 AM
RealQuick's Avatar
By leaving the shop, I menat hiflo's shop. By finesse do you mean cutting and rewelding ... cuz that flange has a long way to go before connecting
Old 04-18-2007, 10:19 AM
52172's Avatar
Ask Beast he got it too fit with lots of HEAT and special sequence of tightening the bolts? He did not break it. Might have to make a spacer out of steel.
Old 04-18-2007, 10:25 AM
smokinHawk's Avatar
id want the wastegate tube to have a flex section or vbands as that is one of the most thermally shocked part as it will heat/cool expand/contract more and be more likely to crack the welds on it.
Old 04-18-2007, 10:31 AM
52172's Avatar
Might have to remake it out of flex pipe? I'll keep adding pics of what will be done with that.
Old 04-18-2007, 10:42 AM
RealQuick's Avatar
flex section or a spacer would be good options.
Old 04-18-2007, 10:53 AM
SSilverSSurfer's Avatar
what size line is on that a1000? -10/-8? im debating on running one of those
Old 04-18-2007, 11:12 AM
52172's Avatar
-10an
2002/Black/SS's Avatar
hey guys were can me and 52172 get a 1 1/2 inch wide flex pipe????
Old 04-18-2007, 11:54 AM
bc56f100's Avatar
Hey is your fuel pick-up in the bottom of your stock tank? Without a sump you better watch the fuel level carefully and not let it get low cause when you get on it and the fuel goes to the back of the tank and uncovers the fitting your F@#$ed!!!!!!!
Quick Reply: Hi-Flo "Street Killer" Install pics
