402 D1 track times
402 D1 track times
It has made around 585rwhp and 780 torque on a mustang dyno a few months ago. .
Finally got a chance to take it to the track. For those that dont know, setup is 402 LS2 with a D1SC. Paceseter long tubes, truck heads, 228/236 cam, ATI converter, 3.73's.
Was run on pump gas, full weight f-body, ZR1 rims wrapped in Nitto drag radials.
I was trying to learn how to launch this thing with the Nittos, traction wasn't that great. Did a couple of 10.9's with a 1.9 60ft. I was feathering the throttle all the way into second gear. Couldn't realy hook.
Last run was:
60ft: 1.711
1/8: 6.77
MPH: 109.13
1000: 8.73
1/4: 10.385
MPH: 136.61
Was trying to get into 9's with a better launch, but oh well... The setup will be changed this or next week. New setup will be..
F1C, Kooks 1 7/8" -2" -3.5" headers, ETP 245 heads, custom EPP cam, Neal Chance converter. I will need a better tire!
Last run was:
60ft: 1.711
1/8: 6.77
MPH: 109.13
1000: 8.73
1/4: 10.385
MPH: 136.61
We just wanted to get an idea of what this thing can do before the setup changed. I was leaving off the trans brake, at under 3000 rpm's, and that way I was pulling the 1.7 60ft's. First run I tryed it off the foot brake, I got a 2.1 60ft.
I will be posting a video of a few of the runs.
This really goes to show why using an automatic is so much better for 1/4 mile times! Not bad at all, I'm shocked the times are as good as they are with Nitto's. Bob
Last run was:
60ft: 1.711
1/8: 6.77
MPH: 109.13
1000: 8.73
1/4: 10.385
MPH: 136.61
Last run was:
60ft: 1.711
1/8: 6.77
MPH: 109.13
1000: 8.73
1/4: 10.385
MPH: 136.61
F1 15 lb boost, 3880 lb car,
interesting, i will be trying out some nitto's on zr-1's, 315's... im sure i will need way more tire than that, but since they are on the car, might as well try while keeping it safe.
good mph... 9's are RIGHT there.... just hook!
I have the shift light set at 6,500.
On the last run, first gear I shifted real early, maybe 5500 rpm's, because I couldn't get any traction, second gear was at about 6400, and third I stayed on it until I hit the rev limiter, which I think is set on 6700 or 6800.
