Average MPG
Lame Excuse for a Photog
Average MPG
What MPG do you turbo guys get on average just cruising?
Also anyone want to take a stab in the dark at what kinda cruising MPG this setup should get.
96lb Inj
A1000 Pump
408 Low compression (9:1)
76mm Single Turbo
4" Downpipe to 4" Resonator for exhaust
About 325-50-15's MT Radials w/ skinny fronts
TH400 Manual Valve Body
4.11 Spool 12 Bolt
My apologies if a thread already exists, search wont work for me
Thanks guys for any guesses,
Rob
96lb Inj
A1000 Pump
76mm Single Turbo
4.11 Spool 12 Bolt
Rob
The 4:10's are gunna kill you for cruising.....
I would get between 8-11 MPG with 3.73's and 28"s out back... (325/50's)
I also think your gunna run out of Pump big time with just the A1000....
Hell even the Eliminator you would run out of Pump.....
What kind of RPM's are you going to spin that motor to??
Whay kind of HP are you looking for with a 408 and a 76mm turbo....
Kyle
Kyle
little off subject, but since we're talking gears.
how do you figure out what gears you need to run?
PG/325 MTDR's.
mainly 1/8 mile but want it gear'd to be somewhat "streetable" and be able to make it down the 1/4.
PG/325 MTDR's.
7 Second Club
PG/325 MTDR's.
PG/325 MTDR's.
Originally Posted by ty_ty13
a streetable gear in a 3speed is 3.73's.... thats what mine will be soon... but right now they are 4.10's... just waiting on some money
well i'll have a glide. guess i'll have to copy Nasty-TA's setup
with 3.73's the car was faster in the 1/8 for me..... so far
But i was out of gear @ 150MPH @ 7K RPM's...
3.54's right now and its nice all around....
Ill have more track info soon...
Kyle
Here's a bunch of calculators. Take your pick
http://www.wallaceracing.com/Calculators.htm
I will not even guess at my MPG. Maybe 6 miles to a gallon at the track . Maybe just Maybe 5-6 miles to gallon on the street, but that was with 3.73's. No idea with the 3.55's
David
David
Originally Posted by anarchy99
I must be inputing sonething wrong. With a weight of 3,850 and a HP of 750, it says my trap speed in the quarter mile is over 1,400 MPH!!!!!!!! I still won't get a cage, bastards!!!!!!!!!!
Need:
RPM (thru the traps)
Tire size
MPH (thru the traps)
Let's say
6800 rpm's
30" tires
150 MPH
= 4:05
6800 rpms
30" tires
165 MPH
= 3.68
Not sure which calculator gave you 1400mph
David
