A.I.R. pump as a power adder?
Old 04-24-2007, 09:47 PM
01redws6ta's Avatar
Default A.I.R. pump as a power adder?
Has anyone actually tried this. Just something I thought of quite a while ago, but had my doubts as to the effectiveness. The hose running to the lid is the intake hose to the pump. Pump activates and draws air from lid normally and sends it into exhaust. What would happen if you used this pump and drew outside air in and sent it into the air intake lid via a manual switch. Of course you would eliminate the actual properly funtioning A.I.R. system. Would this send enough air into the intake (MAF would read it and add fuel accordingly) to make any difference? What do you guys think?
01redws6ta is offline
Old 04-24-2007, 09:51 PM
THE_SUPRA's Avatar
no.
1) there is not enough volume.
2) all the air would just "leak" out of the filter.
it would however give you a crappy idle.
THE_SUPRA is offline
formula001's Avatar
Do that and get the tornado you will have a lot of powa.
formula001 is offline
Old 04-24-2007, 09:53 PM
Pathological Modifier
Ryan K's Avatar
Originally Posted by Carlos Mencia
Dee Dee Dee...
See quote...
Ryan K is offline
