how much boost for LT1??? - LS1TECH
Thread Tools Search this Thread
Old 04-26-2007, 05:20 PM   #1
procamaroz28's Avatar
Default how much boost for LT1???
i have my mind set on getting a blower on my 94 z28 but will my stock block be able to still remain my daily driver with an extra 7+ lbs of boost
what is my boosting limit??
im gonna build a 4 bolt main short block from a vette how much more will that handle???
procamaroz28 is offline   Reply With Quote
Old 04-26-2007, 05:22 PM   #2
do you mean stock internals too?
otherwhitemeat is offline   Reply With Quote
Old 04-26-2007, 05:24 PM   #3
yea all stock exept for my next sb
Old 04-26-2007, 05:28 PM   #4
koolaid_kid's Avatar
While the boost level will be limited due to the compression ratio, your bigger limitation will be the bottom end. If you have a stock bottom end, you will be limited by its strength. Go too high and you may be building that other engine sooner than you think. So your question should be phrased more like "How many rwhp can I run safely on the stock internals?".
koolaid_kid is offline   Reply With Quote
Old 04-26-2007, 06:20 PM   #5
LT1 with the pink pistons and rods can handle 500-600fwhp if everything is right but not forever
Ari G is offline   Reply With Quote
Old 04-26-2007, 07:00 PM   #6
This question is asked weekly on camaroz28.com.
engineermike is offline   Reply With Quote
Old 04-26-2007, 08:04 PM   #7
thanks
Old 04-26-2007, 09:16 PM   #8
Quote:
Originally Posted by Ari G
LT1 with the pink pistons and rods can handle 500-600 fwhp if everything is right but not forever
Hmmmm.
Old 04-27-2007, 04:31 AM   #9
EPP
Take a look at our '95 formula. The internally stock engine has been on 9 psi of boost for four + years.
http://www.exoticperformanceplus.com...tCar.php?car=7
Video http://video.ls1tech.com/video/89b2f...a4011bec07.htm Bob
EPP is offline   Reply With Quote
Old 04-27-2007, 05:19 AM   #10
Thanks, Bob. Is it still running 368 rwhp.?
How many miles does it have on it now?
I spoke to someone last year who said he was running 450 rwhp on his LT1 (mods plus Procharger), but it grenaded on him after about 25k miles.
Old 04-27-2007, 06:02 AM   #11
EPP
Smile
Yes, it is still at about 367-368 rwhp. The 4000 stall give it lower rwhp numbers than what it really is producing. This car only has 5000 miles it, a lot of them are 1/4 mile at a time. Bob
Old 05-01-2007, 08:14 PM   #12
thanks again but before getting the blower i think ill build that 4 bolt beefed up lt1
Related Topics
Thread Thread Starter Forum Replies Last Post
how much boost will a stock ls1 hold 98z28 slide Generation III Internal Engine 6 05-19-2010 01:04 PM
boost psi iceman99 Forced Induction 7 02-02-2007 01:58 AM
6.0 Boost Capibilities mullet_mobile Forced Induction 1 12-17-2006 07:57 AM
LS2 block strength? RUTAN TA Forced Induction 20 01-20-2006 12:59 PM
Boosting LS1 AggieTA Forced Induction 4 04-25-2004 04:46 PM
Tags
368, boost, lt1, rods, rwhp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
