bad bypass valve
Old 04-30-2007, 12:34 AM
Roast1's Avatar
Default bad bypass valve
when i hook up a vacuum gauge, and applly vacuum to my bypass valve it dosent open, is it suposed to? by the way it is a vortech bosh style
Old 04-30-2007, 08:23 AM
11 Second Truck Club
Superado's Avatar
it should stay open under vacuum...are you sure you are applying vacuum and not boost?
while @ idle, the valve should be open...just remove the vacuum line and see if it closes...if it is open @ vacuum, that is ...
Old 04-30-2007, 11:09 PM
Roast1's Avatar
Default bypass valve
what i did is i removed bosh bypass valve from the car and aplied vacuum with a vacuum pump and it dont open do i need a new one?
Quick Reply: bad bypass valve
