OFI low/med boost results
Old 05-06-2007, 08:40 AM
cablebandit's Avatar
Default OFI low/med boost results
the bad...alternator crapped out on the 3rd pass....gotta wrap the dp where it is close to the alternator....heat and an autozone alternator ...not a good combo
1st pass 11.5 psi
1.85ish 60'
10.48 @ 137
2 psi on the 2 step
2nd pass 11.5 psi
1.75ish 60'
10.22 @ 137
2.6 psi on 2 step and leaned the lower boost areas out a tick
3rd pass 11.5psi
1.67 60'.....alternator pooped.....had leaned out the lower boost sections a little more.
I was trying to get a 9 sec pass at 11.5 psi and then crank up the boost but the car would fall on its face out of the hole...I am assuming from being too rich and I found a plug wire almost all the way off when i was removing the alternator.
car weighs 3960 raceweight...heavier than i had expected but means its making good power for low boost. 60' traction was never an issue...just not a good tune down low...not much boost on launch.
I was running 12.5 to 14.5 timing and 110 octane.....10.0-11.5 a/f....trying to start conservative....get it really dialed in and shove the boost to it. Next weekend, I hope to get stuff close enuff to run 18psi or so.
http://cablebandit.net/videos/sdr10-22.MP4 no sound and it looks like the same launch Mightymouse has in his vid
Old 05-06-2007, 09:06 AM
Coal Mining Director
onfire's Avatar
Great start Jerry. 6psi on the 2 step will fix the 60. What rpm is the 2step set at?
137mph at 11 psi is killer.
Old 05-06-2007, 09:15 AM
3300 that time Tom....3500 at Steele netted a 1.49 and that was like 4-4.5 psi. I am just trying to get this thing halfway efficient instead of just throwing power at it. I know eventually I will be 4000 on the 2step but i wanna work on it slowly so I can see what effect changes are having.
Old 05-06-2007, 09:17 AM
Navy David SS's Avatar
Nice start. Looks like you have a lot left in the set-up. Looks like the car was on a lazy summer drive - but at 137mph Gremins will get you every time. Good luck on the rest of the season.
David
Old 05-06-2007, 09:28 AM
Dbluegoat's Avatar
yeah especially at that weight too.......
good stuff man
Old 05-06-2007, 09:40 AM
Tiago's Avatar
congrats Jerry. Great results
Old 05-06-2007, 10:40 AM
Thanks!! With the luck I have had lately...an alternator is almost like no problems
Old 05-06-2007, 10:48 AM
b1er's Avatar
thats true....at least you made it home under your own power...
Went and checked out the video.....looked like someone driving normally away from a red light....lol....
Old 05-06-2007, 11:58 AM
with those kind of launches...add 2 psi and i could run 9s on a stock rear!!
Old 05-06-2007, 12:09 PM
HUNTER02SS's Avatar
Looking good Jerry! Glad to see you are getting the bug's worked out of it!
Old 05-06-2007, 12:32 PM
ozws6's Avatar
Congrats! Very nice #s on low boost.
Old 05-06-2007, 12:55 PM
RealQuick's Avatar
Nice!
Old 05-06-2007, 02:22 PM
NA$TY-TA's Avatar
Lookin good Jerry...
Old 05-06-2007, 03:47 PM
Best part is 2 of my friends were there..B1er and Quicksilverado and we had a good time shooting' tha ****! Goin to the track with my friends is what its all about!!!
My wife saw the launch on the vid and asked if it was slow motion!
I am really happy with the turbo and the performance of the OFI kit....moving this sled that fast at such low boost is pretty awesome.
Old 05-06-2007, 04:05 PM
11 Second Truck Club
Superado's Avatar
great numbers and great that you drove home...
wish I could've been there!
Old 05-06-2007, 04:48 PM
Somebody has to get me my parts cheap
Old 05-06-2007, 05:35 PM
99Z28LS1's Avatar
nice runs..... i like the whole getting more efficient deal. plus after you fix the A/C situation, you'll have a 9 second car with A/C
Old 05-06-2007, 06:08 PM
Boo"SS"t's Avatar
Very impressive! I can't wait to see the 18psi run.
Old 05-06-2007, 07:35 PM
95ZRagtop6M's Avatar
Is this running through a full exhaust? If so, what size?
Old 05-06-2007, 07:40 PM
i did it thru a cutout thats on the downpipe going to my magnaflow
Quick Reply: OFI low/med boost results
