Can anyone ID this turbo... STS haters beware!
take the compressor housing off and send me a pic. From the outside, everything looks the same. Its just a different size compressor wheel.
trtturbo@sbcglobal.net
(I don't know JACK about turbos, that's why I'm asking.)
LS1TECH Sponsor
Originally Posted by RealQuick
Instead of sending a pic... how about just having them measure the wheel since the housing is off Thats the easiest way.
60-1 and 67 are TWO different turbos- they utilize way diffrent compressor blades the physical dimensions are the same between the turbos ( primarily use t3 or t4 based turbine housing and S- compressor housings (to4S)( 4 inch bellmouth inlet with 2.5 outlet)
60-1 has is a older technology T04B design 7 fin design
below is a picture of a 60-1 blade design
the 67 is a 6 fin design with knife edges
roornZ28's is an t04E housing design- same housing on every t3t4E turbo ( 50, 54,57,60,etcc) they use the same housings on many turbos, however the blade size is diffrent, and the housings are machined to accomodate the blades.
[img][/img]
[img][/img]
[img][/img]
[img][/img]
The turbo I posted does not have a bellmouth inlet, just like navymitch12's, but both of the ones you posted do have bellmouth inlets.
Please clarify.
Thanks for all the info guys! In the industry I am in, I need to know all about the competition!
Originally Posted by Ponyhntr
So now I'm confused. Are you saying that the turbo I have pictured is a 60, and so is navymitch12's, when the compressor wheels look nearly identical (and he says his is a 67)?
Please clarify.
Please clarify.
