Biggest cam compatible with FI??
Old 05-09-2007, 11:16 PM
houseylou's Avatar
Default Biggest cam compatible with FI??
How big of a cam would I be able to get and still be able to run a supercharger? Would I be able to use any kind of blower with an MS3 (237/242) or would I just have to use nitrous?
Old 05-10-2007, 04:51 AM
Gold Phoenix's Avatar
I would say it depends on what the LSA is. But again both nitrous and blowers like a cam with a 112-114 LSA. The other thing to think about is the RPM that the cam peaks at N/A, it will be much higher with a blower since the motor is forced fed instead drawing in the air. I also assume this is a stock cube motor. The more cube with the stated cam and blower would bring the peak power points lower RPMs. That is why most cams are between 214 and 228 durations.
Old 05-10-2007, 04:57 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=679
Our blower cam is fairly large, yet it has proven itself in many engines as small as 346 LS1's. Bob
Old 05-10-2007, 06:17 AM
lasvegasgs's Avatar
Bob so how does your cam compare to the Lingenfelter GT2-3 cam?
Old 05-10-2007, 09:04 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,096 Likes on 720 Posts
My blower cam was 236/246//114.
Old 05-10-2007, 12:48 PM
EPP
EPP's Avatar
Thumbs up
The GT2-3 is velvety smooth, while our cam makes it sound like a 60's musclecar. Both seem to work very well in a wide variety of applications. The GT2-3 cam is going to cater more towards the lower part of the rpm scale, and our cam will pick up the middle and upper parts of the rpm range. Bob
Old 05-14-2007, 02:05 AM
lasvegasgs's Avatar
Which cam would make the most power overall lets say if you did alot of Drag racing/freeway pulls?
I really dont care about the stelth aspect as the 345's give it away
Old 05-14-2007, 04:50 AM
EPP
EPP's Avatar
Our blower cam will make more power in the mid to high rpm range, and I think you would be real happy with it. Bob
Old 05-14-2007, 08:20 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Close to mine: 236/245/115
Keith
