Anyone have numbers on there PTK setup
Old 05-10-2007, 08:06 AM
sagres's Avatar
Default Anyone have numbers on there PTK setup
Was curious what kind of numbers people were seeing with there PTK kit. I am currently installing my 4L80e. The kit is on and new motor has been broken in. Here is the setup forged low comp 408 with patriot stg 3 lq9. Comp is about 8.5. Full fuel system with 75lbs and accelronics driver. The problem I have is IM using a t-76 turbo and am pretty sure Ill run out of turbo. I was thinking of putting a s88 with a t6 flange, but as well as most of you guys know its is tight as hell for the 76. So some cutting is invloved to move the rad suport and radiator forward. What should I expect with the 76 and the difference with the 88 if I can get it to fit number wise. Has anyone put a 88 on a ptk setup?
Old 05-10-2007, 08:48 AM
jmeister's Avatar
i have a gt47-88 ptk and will hopefully have some #s soon..
Old 05-10-2007, 09:08 AM
JMBLOWNWS6's Avatar
I need to take pictures of the big red wagon. Hopefully my little red wagon on high boost will keep up with yours on low boost Remember Jess Im off for 11 days. We can get alot done~! No sleep!
Old 05-10-2007, 09:30 AM
bboyferal's Avatar
Give me a couple of weeks... I'm on the second motor... First one took a dump during tuning...
Old 05-10-2007, 09:54 AM
jmeister's Avatar
well jm i work fr and sat,but will be on vacation on mon thru mon so i am ready, and thanks once again..
Old 05-10-2007, 10:32 AM
LS1TECH Sponsor
DrTurbo's Avatar
Call Delk peformance, they have a PTK car they are putting a S80 on.
Old 05-10-2007, 10:59 AM
JMBLOWNWS6's Avatar
Do you ever check your PM's
Old 05-10-2007, 12:07 PM
LS1TECH Sponsor
DrTurbo's Avatar
I responded......just bare with me, I am getting ALOT of PM's.
Old 06-02-2007, 01:55 PM
nossty1's Avatar
I was making 480rwhp through a th400 on 7psi with a cam and ls6 manifold.
Old 06-02-2007, 03:50 PM
Darren P's Avatar
I have a 403 in mine with T67 precision turbo
no numbers yet
I think I am going to be adding a second t67 for sure
it does build boost really quick
Old 06-02-2007, 04:53 PM
W8N2SQZ's Avatar
Any pictures of the car with the 47-88 Jess?
Currently I run a PTK kit on a 347 with stock 317's, stock cam, stock LS6 intake, home ported TB, and a chinesse A2A intercooler. 76GTSH @ 8.5 psi and it made 515 rwhp and 540 rwtq on my last dyno run with no cool down. Intake temp on the last run started at 91 degrees and ended at 108ish and that was with 5 back to back runs with under 5 minutes between pulls. Now it is at 10.5 psi and I have not dynoed it.
Forced inductions is coming out with an S88 on a T4 flange. I feel this will be an option. Currently my 76 shoves about 97 lbs of air and the new T4 flanged S80 pushes about 122 lbs of air, so the S88 hopefully will blow a little more than that.
Glenn
Old 06-02-2007, 05:01 PM
RW99's Avatar
I'm just a T67 on stock cubes, but happy with the kit (spools fast). Running about 11 psi through a 78 mm FAST and AFR 225's 72cc with methanol.
Old 06-02-2007, 06:53 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
Glenn
how are you pushing 97lb/min of air and only making 515rwhp?thats not right.
for reference im pushing 53lb/min of air and making 530rwhp on 7psi
Quick Reply: Anyone have numbers on there PTK setup
