Procharger Oil Leak
Procharger Oil Leak
Just changed the oil in the blower and there's a little buildup on the bottom now. That was without starting it up. Is that normal? I'm thinking it might go away, I hope, after running it and heating it up a few times. It wasn't leaking when I took it off.
I can almost guarantee that it is coming from the dipstick. Replacing the gasket under the dipstick normally takes care of the problem. There is a new gasket taped to the top of the white boxes that ProCharger packs the 3 extra bottles of oil in. Bob
procharger
i see you guys are running pro-chargers. how do you like them? i plan on having one put on my 94 HAWK...LT-1. i here alot about them good and bad. this will be done by thunder racing,also a 12 bolt will go in. it's auto with a racing built 60-e. the car is stock except for that and nitto 315-17 555R. i would like around 450 hp,that should be easy with a pro on it. am i looking at about 6000-7000.00 for this? ..........any input would be great...thanks..RON
Check out our '95 Formula with an ATI ProCharger P-1SC.
http://video.ls1tech.com/video/89b2f...a4011bec07.htm
Here is a video we puit together. Bob
