Turbo Auto vs Turbo 6 speed from 40 to 160mph??
Auto usually wins, area under the curve and average HP.
A stalled auto will put more average HP to the ground due to losing less RPM between shifts (rpm extention keeping the motor around peak HP) and not dropping off boost between shifts. Don't forget you just about eliminate the chance of missing a shift.
I've had a 6spd in my car and now a th400, there is no comparison, the TH400 is MUCH faster even from a roll. I dunno why people think autos don't have top end pull lol
Chance of missing a shift is irrelevent. The comparison doesn't factor in driver error, its about what setup is better, all other things being equal.
The only disadvantage that the manual has is losing boost between shifts. The effect of that depends on the size of the turbo whether or not the driver is powershifting.
Originally Posted by ONEBADASSWS6
Stalled auto will not put more average HP to the ground, because when properly driven, a 6 speed with 4.10's will never fall out of the powerband either. It will always be within a few hundred RPM of the previous gear, meaning it stays in the powerband.
When I tell people I got rid of my 6spd for my 3spd auto people alway ask why and tell me how autos are slower, especially from a roll.
It's really hard to beat a good running auto car. I think autos have such a bad name due to dyno numbers. My highest a3 dyno to date is 470 RWHP, but I get a 3850lb behemoth to run 10.5's @ 130 with that dyno number.
P.S. I was a die hard 6spd guy previously. Behold the power of the darkside
Murdock is absolutely right rear end gear is irrelevant. Beside the fact is that most turbo cars like more gear (speaking as a ratio and not numerically ie. 3.27 vs. 4.56) and they don't need it to get the car moving because turbos are load dependant and make a tremendous amount of torque once this load is established and the turbos are "spooled". Very few people that know what they are doing would ever have 4.10's in their car by choice. To answer the question the auto in my opinion would have a chance of being quicker because it has a constant load.
Assuming both motors make the same amount of power at the crank... the 6 speed will win. Less drivetrain loss. Now if both rear wheel HP were equal, then I would give it to the auto.
Less gears the better
http://home.comcast.net/~lowrider1998/ray197.wmv
449ci sbf / twin 88mm turbos / 2 speed
Someone needs to find an A4 and M6 turbo car with close to equal rwhp, and race from a 40 roll. It shouldn't be too hard to find those cars in the same area. Post up a vid. My money goes on the M6.
I'm an M6. Anyone in the SD CA area with a turbo auto making about 425 to the wheels?
