Carb Intake/ Elbow throttle cable?
Old 05-15-2007, 07:15 PM
Slow Z28's Avatar
Default Carb Intake/ Elbow throttle cable?
you guys got pics how you are mounting your throttle cable for this style setup? I guess I'm just not that bright, hahaha
Chris
did a search here an external section, and neither had anything for a wilson/precision elbow, just that intakeelbows.com thing...
Old 05-15-2007, 11:14 PM
Navy David SS's Avatar
Let me see if I can explain mine - and an attached picture.
Built a plate for the T/B that puts it in aline with the next plate; built a plate attached to the intake with a tab attached with a notch in it for the throttle cable. Stock throttle cable - but will be changing it out for a LoKar cable. But will be same basic set up. Worked great, but the new cable will be better.
Hope this is what you were looking for.
David
Attached Thumbnails Carb Intake/ Elbow throttle cable?-throttle.jpg
Old 05-16-2007, 10:04 AM
Slow Z28's Avatar
Thanks David....
kinda what i was looking for. what throttle body is that? it looks like the linkage is reversed from normal for an LS1(the cable coming over the top)
Old 05-16-2007, 11:35 AM
copbait's Avatar
I'm using copbaits - up to the shop heading for Indy. It's an Accufab T/B.
David
Old 05-16-2007, 12:23 PM
Fireball's Avatar
I drilled two holes on the side of the elbow, tapped the holes then bolted the bracket to the side.
Old 05-16-2007, 12:39 PM
Slow Z28's Avatar
any problems sealing the holes?
guess that'd be the easiest way, just didnt' want to cut up the nice looking elbow, haha
Old 05-16-2007, 04:42 PM
Fireball's Avatar
I haven't tried it boosted, but it was fine N/A. thread sealant goes a long way I think
Old 05-16-2007, 06:04 PM
Deerhunter-Z28's Avatar
not sure
Old 05-16-2007, 08:47 PM
SVC707's Avatar
just get creative bolt/weld something on and grind it to fit the cable attachment
Quick Reply: Carb Intake/ Elbow throttle cable?
