1000 rwhp-aluminum or iron block
Old 05-17-2007, 01:19 PM
eb02z06's Avatar
Default 1000 rwhp-aluminum or iron block
Hey guys-just thinking ahead and since there are probably so many on here that can easily make these #'s or have already have-I figured you would know best. If you where to build a motor with a goal of 1000 rwhp-would you use the 6.0L aluminum block or the iron block-no LSX blocks allowed. No strokers-just a 364 or 370 max. Another thing what about the crank-stock or aftermarket.
Thanks!
Old 05-17-2007, 01:29 PM
MOLESTER's Avatar
Originally Posted by eb02z06
a motor with a goal of 100 rwhp-would you use the 402
Thanks!
i think you already made your goal
Old 05-17-2007, 01:31 PM
eb02z06's Avatar
Man-I gotta learn how to type!
Old 05-17-2007, 01:42 PM
LS1Tech Sponsor
hellbents10's Avatar
Iron for durability. Less core shift and such with extended use. Just my 2cents.
Old 05-17-2007, 05:50 PM
01ramair500hp's Avatar
i chose the 6.0 iron block. I have the same goal you do, and i hope i made the right choice. i will be doing a 408 tho.
Old 05-17-2007, 09:17 PM
HUNTER02SS's Avatar
6litre iron block here.I think the aluminum block will distort under alot of boost.I was told to go with Iron for the durability,so I did.
Old 05-17-2007, 09:26 PM
camarols1's Avatar
+1 for Iron if you don't mind the extra 88lbs, that is what I picked for
my build with similar goals.
1000hp is common now with aluminum blocks, but you know things will be moving around
inside an aluminum block at that power.
I am not racing for money, so iron block for me!
Old 05-18-2007, 05:43 AM
EPP
EPP's Avatar
For 1000 rwhp, I'd go iron if you are talking about stock blocks. Bob
Old 05-18-2007, 06:32 AM
2001WS6Vert's Avatar
Filled 364 C.I.D. W2W LS2 here. More than a few have shown what the aluminum can handle. Harlan, Mike Brown come to mind (both low 8 sec. cars). I thought I read Major Spray was an LS2 (7 sec. car)? You can make a good case for iron at the 1000 rwhp level, it surprises me though how many carry the extra weight of iron here that have 500-700 rwhp, I see no reason. The coolest thing about the LS engines and what is making them take over the SBC in street rods and other custom applications is the fact that they are full aluminum. The stock crank is another very stout piece that has shown it can hold at the 1000 rwhp level (we're not running one of those though.
Old 05-18-2007, 08:18 AM
cablebandit's Avatar
all the cars you mention are not daily drivers using stock type motor mounts.
Old 05-18-2007, 11:18 AM
6 Second Club Moderator
LASTLS1's Avatar
I know of a 6l iron block that will be going for sale.
Old 05-18-2007, 11:46 AM
CHRISPY's Avatar
I would go iron 6L Arun...The weight is a bit of a pain but the block will handle it better on the street than a half filled alum block
Quick Reply: 1000 rwhp-aluminum or iron block
