WG spring
WG spring
Anyone know what # spring comes with a Turbosmart 38mm Street Gate? How much can a E-Boost 2 controller vary boost? I want to run 10-16lbs of boost. Do I need to buy a differnt spring?
Thanks - Ron
Thanks - Ron
AFAIK the WG comes with whatever spring you specify from dealer. Otherwise 7psi is common as well, but what color is it?
OK, went to the website. There is no color chart, but it says it comes with a 7psi spring (inner). You can buy 3, 5, 10 outter springs. So, that being said, the 7psi spring will support 14lbs of boost? If I buy an outer one, say 3psi than the boost will be adjustable from 10-20psi?? What happens if I would like to lower the boost (like with E-boost 2 controler) down to 5psi? I will probally like to set it up so I have the lowest amount of boost possable in first gear. Is there a way, or does the E-boost controler make it adjustable from say- 5 to 15lbs?
Thanks for the replies, I really apprecitate your guys help!
Ron
Ron
