What Dual Springs do you HIGH rwhp FI cars run?
Old 05-24-2007, 03:48 PM
Shorty Director
VINCE's Avatar
Default What Dual Springs do you HIGH rwhp FI cars run?
I am curious to what valvesprings you run?
Old 05-24-2007, 03:50 PM
pdanrichey's Avatar
I run the patriot duals...but I'm at ~500, not too high.
Old 05-24-2007, 03:58 PM
Tiago's Avatar
I was running hte AFR springs, but now I chose to go with the comp 921s over the patriots on my ET heads.
Old 05-24-2007, 04:07 PM
SuperZ's Avatar
I run PRC dual springs.I have about 10k miles on them and there doing fine
Old 05-24-2007, 04:31 PM
black98ws6ta's Avatar
Whats high I made 920 rwhp on a mustang dyno with patriot duals, stock lifters, and stock rockers.
Old 05-24-2007, 04:34 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
how good are the stock lifters and rockers on high hp applications?
Old 05-24-2007, 04:47 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,096 Likes on 720 Posts
I'm running stock rockers. I'm running ETP springs now, but I have run several other springs in the past.
Old 05-24-2007, 04:54 PM
BIG BAD BLACKSS's Avatar
Any of you guys running stock rockers have em rebuilt?
Old 05-24-2007, 05:39 PM
Ed Blown Vert's Avatar
I currently run Patriot Golds. I prefer Comp 921's
Stock rockers and Comp oem lifters.
Old 05-24-2007, 05:42 PM
52172's Avatar
comp 921's
Old 05-24-2007, 06:09 PM
qqwqeqwrqwqtq's Avatar
We get springs from ET and set them up at around 185-195 on the seat in conjunction with comp stock replacement lifters, stock rocker arms, and 1,100+rwhp/7,500+rpm.
Old 05-24-2007, 06:19 PM
Shorty Director
VINCE's Avatar
Sounds like what I need...
Old 05-24-2007, 07:04 PM
Tiago's Avatar
my stock rockers are rebuilt
Old 05-24-2007, 08:03 PM
Shorty Director
VINCE's Avatar
I also run stock rockers...
Old 05-24-2007, 09:14 PM
engineermike's Avatar
Crane 99893's set up at 155-160 lb on the seat, stock lifters.
Mike
Old 05-24-2007, 09:24 PM
helicoil's Avatar
Default springs
How the springs hold up for 500 miles?
Old 05-25-2007, 06:40 AM
nmp27's Avatar
921's here - I have a set of PRC's with 500 miles on them for sale if needed
Old 05-25-2007, 06:45 AM
Fireball's Avatar
Mike
those are the same springs on my ET heads being used for my GT47 build
Old 05-25-2007, 07:24 AM
Tiago's Avatar
they were fine, I never had any valve float so they did what they were supposed to
Only reason I switched heads is because of the 6 bolt/cyl LSX block
Old 05-25-2007, 10:10 AM
Shorty Director
VINCE's Avatar
The main reason I made this post was to help others understand what works. Each car is going to be different, but there should be information out there to get people started.
I run CC921's, but I think I need more seat pressure. I am around .045-.050 on the shim right now, but due to valvespring harmonics/resonance around 5200rpm to 5500rpm I think I need to shim some more or go with a much stronger spring.. I guess that is what you get when your car makes over 750rwhp on the wastegate spring..
