where is everyone spraying there methonal?
Old 05-28-2007, 01:32 PM
Boostaholic's Avatar
Default where is everyone spraying there methonal?
Before or after the intercooler? If after how close to the TB?
I'm on a SD tune so no MAF to worry about
Old 05-28-2007, 01:57 PM
KraZy's Avatar
I'm tapped right at the throttle body
Old 05-28-2007, 01:58 PM
cablebandit's Avatar
afte the intercoolers when i had the incon.....after the maf but before the tb
Old 05-28-2007, 02:44 PM
Ok sounds like I'll put it on the intake bend right before the throttle body
Old 05-29-2007, 02:56 AM
BOONE's Avatar
I think if you sprayed before the intercooler you would get a lot of fallout. I remember reading a post from alkycontrol a long time ago where he said the best place was (If I remember correctly) the last 6 to 8" before the intake.
Old 05-29-2007, 09:22 AM
great421's Avatar
LT1 car here - Mine in plummed into the aftermarket metal / Aluminum elbow about 3 inches before my IAT sensor.
Old 05-29-2007, 11:15 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Keeping your car now?
Old 05-29-2007, 12:57 PM
BoostnTBSS's Avatar
Before The turbos here!!! about 12-14 inches pre turbo. its like a half draw thu set up and it puts frost on the intake pipes and intake
Old 05-29-2007, 01:26 PM
Fire67's Avatar
Julio @ Alkycontrol said you'd get the best IAT results with the meth entering before teh blower, but cautioned that the mist would actually wear the edges off the blades of the impeller.
I have mine about 4" prior to the IAT sensor, it sits approx. 1 1/2" - 2" from the TB.
Old 05-29-2007, 02:39 PM
Doing what was suggested and fixing all the small crap, I think everything is done now except suspension parts and I plan to spend a bucket of money on that pretty quick here.
Car revs to 6500+ now without missing a beat, has exhaust done, no more coolant line or overheating problems, etc
But I do plan on keeping it now long as I can, I really need to pay it off so if I ever loose my job again I can afford to just put it away for a while. No sense owing money on a race car
Old 05-29-2007, 04:39 PM
dixonk's Avatar
How bad will the mist wear down the blades? This actually interests me if it works. Any link to the thread or site?
Old 05-29-2007, 05:38 PM
bhz28's Avatar
subscribing
Old 05-29-2007, 10:54 PM
DeltaT's Avatar
I don't like the idea of pre-IC injection, because if you ever have a backfire, your expen$ive FMIC is the thing that's going to blow. Also, you want the FMIC to extract as much heat as possible, and injecting alky before it compromises the heat extraction.
Jim
Old 05-30-2007, 02:12 AM
dixonk's Avatar
So not as safe as pre throttle body? What about injecting after the throttle body into the egr port on the intake?
Old 05-30-2007, 05:58 AM
EPP
EPP's Avatar
Smile
Kevin, the location shown here worked out very well for us. Bob
Old 05-30-2007, 09:50 AM
BoostnTBSS's Avatar
Ya but but i run no IC with my twin meth kit pre turbo and IAT are below 30* @15-24psi. But yes a back fire can be a problem!!! but there are always pros and cons and in the 15 years of injecting fuel before the turbo only once have i had a backfire. So on the street with a IC it might be the best way but on the street but i dont run high boost so i dont need meth to cool the charge that much.
Old 05-30-2007, 05:11 PM
dixonk's Avatar
Got it Bob I guess I will go with that method.
Old 05-30-2007, 06:33 PM
SSmokin 01's Avatar
After Maf and a little in front of and across from the IAT. I'm going to have to move it in-line with the IAT as the mist from the nozzle never reaches it at WOT.
Old 05-30-2007, 06:44 PM
CALL911's Avatar
Thats where mine is. Just got it tuned on it today, and seems be working like a champ.
Old 06-01-2007, 06:47 PM
Bonswa's Avatar
actually, for my supercharged 2000 grand prix gtp. i purchased a $45 throttle body spacer and tapped it into there in case i decided to remove it further down the line. i know the ls1 and lt1 has a spacer that you could use as well.
Quick Reply: where is everyone spraying there methonal?
