Procharger + Nitrous = Which Plug?
Well guy's, Im bumping the boost on up to 10lbs and throwing a 75 Dry shot on the ol' Camaro this week. My question is, what Spark plug should I go with? Plain and Simple...
Did my fair share of searching and found nothing.
Thanks, Blake
Thanks, Blake
Hey guys just wondering if I should try a dry shot of nos on my car i am @ 12.6 boost with a ds1c procharger 3.4 inch pulley twin inter coolers. dyno at the rear wheels 601.2 HP 558 or so tq. can i run a shot or not?
Originally Posted by Ed Blown Vert
I am still running TR6's
With the increase in cylinder pressure and heat from boost plus nitrous you'd be a FOOL to run a tr6. Need to look into the NGK or equivalent race plugs with a non projected tip at least 2 heat ranges colder then the 6's.
Originally Posted by WOTFMAN
didnt you just blow up some parts not too long ago?
Yep, but that was because I ran out of fuel on a single pump. Not because of the plugs.
11Second Club
You're pretty bright man. What is your reasoning that you don't run the correct heat range plug in your car?
Originally Posted by Gauge
Hey, why don't you back off there, chief. Ed never said what he did was the best option. He simply stated what plugs he uses. No need to be a *****.
if it was my car, i would put TR55s in it.
reason being, i KNOW it needs a colder plug, but going colder then 55s will greatly increase the potential to foul out with street driving.
ideally, i would want to run a plug colder then that.. but i would atleast feel safer with the 55s... although in my head i realise thats a "good enough" approach (a compromise) and not ideal.
11Second Club
Oh my. a 8, 9, or even 10 can be driven on daily if the person wanted it to be. Trim the fueling at idle back some and clean up the AFR there throw some timing in the low and midrange and theres no reason you should foul them out.
i just know a few people (that know what they're doing) who do have that problem..... in anycase, thats my perspective on it for a street car. like i said, even i know its not ideal.. its a bit of a gamble/compromise... if you wanted to err on the side of safety then yea, run a colder plug then that.
Don't forget spraying Nitrous will also cool down the intake charge.
The TR6's is working for me, I see no reason to change yet.
You seem a little caught up in the cooling of the intake charge to forget that with nitrous regardless of its cooling effect, is still a power adder and increases cylinder pressure. With cylinder pressures, comes heat. Your plugs would have also aided in the extreme melt down you had. Plugs extract heat. Thats there job. Happy motoring.
