highest CR you 9 second guys run on S/C
7 Second Club
just curious how high a compression some of you 9 second are running and actually how many of you there are...
i did my formula last night to check my CR and i'll be damned if im not about 7.9:1 CR.... im thinking about using some ET 255 heads milled to about 58cc and hitting about 9.0-9.2 and still using this little D1 then maybe next year slapping a big blower on there (f1r)...
LS1Tech Co-Founder
I was 8.0:1, YSi, and went 144mph at 18psi with no real work on the tune from when the car was dynoed. I probably could have added a lot of timing and hit 147mph or more pretty easily... I ran 19-20 degrees of timing with C16 which was beyond safe.
7 Second Club
Originally Posted by smokinHawk
id keep the CR ratio at the 7.9 or maybe use a slightly thiner gasket to get 8.0-8.3 and run more BOOST
In reality one point of compression isnt going to make huge difference, unless you are limited by the size of the blower then it makes a good difference. If it was that easy to eliminate detonation dropping a point or making 100 more hp by raising compression a point, that would be awesome but it doesnt work that way - unless you are limited by turbo or blower size.
LS1Tech Co-Founder
I think if you want to make 1000hp with a blower you will need to run cogs or a 12 rib setup. Personally I would source custom 12 rib pulleys over cogs, because cogs belts are very expensive.
There is a reason why folks say that you need to make 1 more lb of boost for every 1 pt drop in compression... If you say that the goal is 1000hp, and that 8:1 will make 3% less power at the same boost level as it would at 9:1, you need to make up 30hp.
I think a lot of folks can run 8.5:1 - 9.5:1 and it's all fine. At the higher compression levels you just need to use higher octane gas or meth since your IAT's and engine temps are higher.
My compression is about 9.3:1 or 9:1 ish and it definitely doesn't feel as as strong as it did with 10:1 compression.
I personally think your compression is pretty damn low. Unless you are going to compensate by running a real big blower.
At 9 sec levels you are pretty much running C12-16 anyway.
Originally Posted by cablebandit
i am happier at 9.3 than i was with the 8.2 i had. Car is better off boost and it gives my turbo more room though it will require more octane to max it out. I saw it working for KP so i figured I'd copy what was working.
Bottom line is compression makes heat, boost makes heat, if you can keep them under control then you are doing OK. If you cant you blow **** up no matter what the compression. There is nothing wrong with runing 8:1 compression but you are going to have to make up for it with more airflow, thats fine if you have the surplus and not fine if you dont
And I also disagree that you need a 12 rib or cog to make 1000hp with a blower, maybe you do with 8:1 compression and a huge cam. Arun is at 920 with an 8 rib and I bet he cracks 1K - and thats with the same belt that drives everything else. I am driving an F1A (which is bigger then your YSI) just fine with an 8rib and it will go much further. I doubt it will run an F1R at full speed but you never know..
Originally Posted by ty_ty13
so are you thinking an f1a is as big as a 8rib will run consistantly?
Originally Posted by kp
I dont like to speculate, I KNOW the SDCE 8 rib will run a F1A to 68K impeller with no issues. Other then that I have no idea What people tend to forget is how slow a car accelerates on a dyno compared to 1st gear at the track, thats when the belt will slip most. So just because it holds on the dyno doesnt mean it will hold making a pass in 1st, once they start slipping they tend not to stop the whole way down. Thats why logging boost is very important and its very easy to see belt slip in 1st gear.
LS1Tech Co-Founder
Kevin, I am suggesting the 12 rib because while Arun is making great power, keeping belts on in street driving at big power levels is very problematic.... Sure an 8 rib can make 1000hp, the NMRA Renegade guys run 8.5's and faster with 8 rib belts.
You said you needed a 12 rib or cog to make 1000hp, and now it does not I wouldnt have any problems street driving mine at all. I can grab the belt and move it 3" with very little force which means almost zero wear and tear on the idlers and the belt itself.
You seem to be fixated on the belt thing, sure the F2+ and X trims arent going to work with an 8 rib, thats simple physics. But 1000hp is doable on a street car with a mid sized blower IMO.
i guess ill have to get the damn sdce tensioner sometime or another
