Water pump for Air to water IC
Old 05-31-2007, 01:35 PM
7 Second Club
Phil99vette's Avatar
Default Water pump for Air to water IC
I've heard of a few guys using a pump from precision that moves about 65 gallons or so, what options are out there??
Phil
Old 05-31-2007, 04:00 PM
Z8'S's Avatar
I have a Meziere WP336s 55gpm.
Old 05-31-2007, 04:10 PM
turbo'd stang's Avatar
Rule 17a...3800GPH
And there is another, water puppy, not sure what it is rated at. I'm using this one.
They are all bilge pumps.
Old 05-31-2007, 04:41 PM
MIGHTYMOUSE's Avatar
mine
http://www.pumpagents.com/SimerPumps/BW85P.html
Old 06-01-2007, 02:45 AM
NA$TY-TA's Avatar
Phil,
Im using a marine pump........ way cheaper and works just as good.....
Old 06-01-2007, 06:48 AM
Fireball's Avatar
Originally Posted by NA$TY-TA
Phil,
thought you were a2a?
I have a meziere pump
Old 06-01-2007, 09:03 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I will be tracking this thread. I am thinking about switching over to a A2W setup.
Keith
Old 06-01-2007, 11:14 AM
NA$TY-TA's Avatar
I am...... but while my motor is out for the blown head gaskets were O-ringing the block, copper head gaskets, A2W setup, bigger cam, and something special
Kyle
Old 06-01-2007, 06:22 PM
7 Second Club
Kyle,
Sounds like your taking it to the next level. I'd love to check your car out in person one day.
I just got a smokin deal on a Garrett 2nd gen IC - 3000hp A2W intercooler custom setup for my car with 1" NPT feed and return. Also got a custom water cell with 1" NPT feed and return. Plan is to run the water cell to a Rule -17A water pump(3800 GPH @ 12v) running 16 volts to 1" tubes, to the IC and than to a radiator up front and back to the tank. Should be perfect for the track and cruising the city.
Old 06-05-2007, 04:28 PM
7 Second Club
Anyone else?
Old 06-05-2007, 05:54 PM
LTLHOMER's Avatar
Ran the meziere wp136. Think it was 20-25 gpm. We clocked it at a whopping 4 gpm in its working environment.
Old 06-19-2007, 03:14 PM
7 Second Club
I just ordered a Rule 17a(3700 gph) for my setup, I'll post pics when I figure out how to hook it up. I'm thinking about using a 1.5" aluminum bend dumping down into the inlet off the water cell.
Old 06-20-2007, 01:32 AM
chuntington101's Avatar
off topic but have any of you guys upgraded your pump form a smaller one??? did it make much differance to the inlet air temps? also how did it effect heat soak?
thanks Chris.
Quick Reply: Water pump for Air to water IC
