couple mor pics of my diy rear mount!
Old 06-01-2007, 08:08 PM
Eatinstang4life's Avatar
Default couple mor pics of my diy rear mount!
pics taken with phone sorry
Old 06-01-2007, 08:13 PM
BigBenz's Avatar
nice ****. I love diy projects.
Old 06-01-2007, 10:24 PM
Boostaholic's Avatar
i cant believe that oil return works
Old 06-01-2007, 10:47 PM
6techniques's Avatar
good job man, diy will always be cool in my book.
Old 06-01-2007, 11:24 PM
Well It does
Old 06-02-2007, 01:44 AM
99Z28LS1's Avatar
good job man, i like the less bends
Old 06-02-2007, 02:37 AM
jeffboy757's Avatar
am i crazy for trying to do mine over the axle?? it seems noone else is
Old 06-02-2007, 08:56 AM
THE_SUPRA's Avatar
looks good bud.
Old 06-02-2007, 10:22 AM
JAvenger007's Avatar
Looks good. Any more detailed pics of your FMIC?
Just go under. much easier and cheaper. you dont lose ground clearance.
Old 06-02-2007, 03:43 PM
I will take some good pics sometime soon. I never took any pics with fmic on and bumber off
Old 06-02-2007, 04:40 PM
few i took with digital camera today
manifold for boost/vac reference for bov and wg and boost gauge
Old 06-02-2007, 04:58 PM
Lookin pretty clean. I like the xspower WG
No WB? what guages are you runnin. What is that crazy contraption of tubing and T's youve got for the PCV??
btw is it a T60 or 67?
Old 06-02-2007, 07:50 PM
thanks, hey the xspower works but you should see my boost curve lol!! its a roller coaster. I will eventually get a tial
I still need to clean up the pcv set-up I have it set up with check valves so that normal driving the crank case vents like it originaly has, and during boost its vented into the atmoshphere through the breather after catching oil in the catch can.
No WB as of yet just fuel pressure and boost gauges for now
T60 turbo
Old 06-02-2007, 09:11 PM
Originally Posted by Eatinstang4life
Well It does
seems like you would want the pump to be down near the level the oil fitting on the turbo is then push it upstream to the engine. then again i have not researched rear mount setups very much so i wouldnt know
Old 06-02-2007, 09:14 PM
boost curve? whats it doing with your current WG? have you tried adding a cheapy boost controller?
still nice solid numbers for T60. ive got same setup. sorry for the 20Qs but Whats your fuel setup?
If you wanna clean things up you could run get a breather for the oil cap, then run the two ports on the pass valve cover to catch can w/ breather and then a line coming off catch can to intake of turbo. Then use the port on the back of driv side valve cover for the return oil. And plug TB and manifold ports
Old 06-02-2007, 10:12 PM
On the dyno We monitored boost it was pretty wavy, I have a turbonetics manual boost controller out back nect to the wg,.
Yea those numbers were before when it was missing I need to put it back on the dyno soon and prob touch up the tune
As for fuel, just intank walbro 255, new fuel filter, ford 42LB injectors
Old 06-03-2007, 03:05 AM
99Z28LS1's Avatar
thats exactly what i have...... you should be making some good power with more psi. the only thing i have now that you dont is the cam, springs and rods. be nice to see what your car would make with 7.5psi or something.
goodluck man
Old 06-03-2007, 04:43 AM
bcs
bcs's Avatar
Nice work.. Did you cut all the foam out for your fmic?
Old 06-03-2007, 02:11 PM
yhanks, i took the foam out
Quick Reply: couple mor pics of my diy rear mount!
