Car is almost finishe!!!
Car is almost finished!!!
I am getting ready to get my new twins setup tuned. I do not get much time to work on it with work and all. But I think that I finally got everything ironed out. I am doing an Incon setup with the dual walbro's. What do you think that she will make power wise. Here is what I have for setup.
Will be tuned for 10 #'s
stock compression
around 14 degrees timing
12.0 a/f
twin gt28's
twin walbro intank
typhoon intake
2 bar map
Obviously I will adjust the tune a little if need be but, this is about the basics. So what do you think? 400 to 500, 501 to 600, or KABOOOOM. I have another block being built currently so If she does go then Oh Well. If she does last, I am then going to swap in my 230/228 cam and get a little comparison with that. If she lasts through that. Then I will do another. I really am not expecting to much....
It will be fun though!
The Critics say:
Superman = 550
Inspector12 = 570
ddnspider = BOOM
stock compression
12.0 a/f
twin gt28's
twin walbro intank
typhoon intake
2 bar map
The Critics say:
Superman = 550
Inspector12 = 570
ddnspider = BOOM
LS1Tech Sponsor
Im going to guess 550 rwhp with an auto, and maybe closer to 600 with a stick? stock compression with 10#s should do some pretty good numbers, make sure the tune is spot on or the shortblock may not like you.... but that will be a reason to upgrade right?!?!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS1Tech Sponsor
if its a stock 4l60-e, that will hate you much more much sooner, haha. Im praying for mine as well.... I actually am getting tuned this week as well!
__________________
Originally Posted by Boostaholic
I'd go 11.5-11.7 AFR and shoot for 15-17deg timing
I will see how good the tuner really is, if he gets to 11.5 and says that he can not go above 15 deg timing with out knock I may have to settle for that.
Originally Posted by Inspector12
I'd bet in the 570 range if everything is right and depending on how aggressive the tune is I was running 20 deg on mine with @8-9lbs on 93 and I made 601rwhp and it lasted a good while.
BOOM on a hot day beating on it with a 12:1 A/F
Originally Posted by Mike 01WS6
Mine lasted on 10# for about 15k.
WTF is a Typhoon intake? I hope to Jesus it's not like a tornado or something similar.....
Originally Posted by 02Vortech
stock transmission?
