Tried search need Magnaflow Ipipe part# for STS kit
Old 06-06-2007, 12:09 PM
vipvegas's Avatar
Default Tried search need Magnaflow Ipipe part# for STS kit
Looking for the Magnaflow I pipe part number. Someone gave us a link in this forumn to the part at summit. tried searching couldnt find.
Old 06-06-2007, 01:21 PM
Blackbird's Avatar
I got the dynomax version from Summit. May want to search for that.
It and the over the axle pipe were very reasonably priced.
Old 06-06-2007, 03:50 PM
99Z28LS1's Avatar
i got my special i pipe from trt for $40
they also sold me a kit that deletes the over the axle pipe for $40 too
Old 06-06-2007, 07:16 PM
WS6FAST's Avatar
99z28ls1, do you have long tubes and then exhaust is wrapped all the way back from headers back ?...
Old 06-06-2007, 08:59 PM
CamaroSS_2002's Avatar
WLK-54064 and WLK-53061 -- found on summitracing
Old 06-06-2007, 09:19 PM
trtturbo's Avatar
thats the one to use.
Old 06-07-2007, 03:32 PM
99Z28LS1's Avatar
yes sir
Old 06-11-2007, 02:58 PM
vipvegas's Avatar
why are there 2 part #'s. Im looking for the exhaust portion that runs over the rear axle feeding the turbo exhaust.
Old 06-12-2007, 02:01 PM
vipvegas's Avatar
anyone ttt
Old 06-12-2007, 07:14 PM
JAvenger007's Avatar
Look up those #s on summit. They show a pic of them and you can see which goes over the axle clearly. I think it says in the description too.
Old 06-13-2007, 10:51 AM
vipvegas's Avatar
description is the same and the pictures look almost identical they are just flipped around
Old 07-19-2009, 08:04 PM
vipvegas's Avatar
ttt bump anyone
Old 07-19-2009, 08:51 PM
vipvegas's Avatar
will the Dynomax Performance 53061 that summit sells with 3 inch outside diameter but up to my pipe with sts so I can weld it...
Old 07-28-2009, 11:26 PM
vipvegas's Avatar
Well ordered pipe, does anyone use this pipe to weld up to turbo exhaust pipe supplied with STS kit? Seems to be the only option for replacement of just that section over the axle and reason for me replacing it is my system is Aftermarket dont know brand no stamping but is full stainless so cant weld...
Quick Reply: Tried search need Magnaflow Ipipe part# for STS kit
