AFR225 head gasket question..... - LS1TECH
Thread Tools Search this Thread
Old 06-07-2007, 04:01 PM   #1
ninetres's Avatar
Default AFR225 head gasket question.....
I have a 364ci and am going to switch to the 225AFRs with the 72cc chamber. Tony at AFR said to run a gasket with at least a 4.125" bore to properly match the heads.
What gaskets are you guys running with the 225s and similar cylinder bore as mine? Thanks in advance guys.
ninetres is offline   Reply With Quote
Old 06-07-2007, 04:05 PM   #2
Tiago's Avatar
I ran GM MLS gaskets for the 6L blocks with 4.0 bore, I had a 346 motor. It worked.
Tiago is offline   Reply With Quote
Old 06-07-2007, 04:16 PM   #3
E Wagz's Avatar
I ran the GM LS7 gaskets,on my 402/6.0L with the AFR 225's.
E Wagz is offline   Reply With Quote
Old 06-07-2007, 04:42 PM   #4
JMBLOWNWS6's Avatar
I ordered the new Felpro MLS.
JMBLOWNWS6 is offline   Reply With Quote
Old 06-07-2007, 04:45 PM   #5
ninetres's Avatar
Quote:
Are those the ones that are supposed to have some fancy ring in them that seal under all conditions or something???? Anyone know what I'm talking about????? I've just heard rumors. I've also heard rumors about some gaskets that are like ~$250 a set
Old 06-07-2007, 04:58 PM   #6
JMBLOWNWS6's Avatar
Quote:
No those are the Cometics. And W2W pushed them to about 23 psi and they pushed out. They also require silicone to seal. I was going to order these but I spent the extra money on L19 head studs.
http://www.cometic.com/phuzion.aspx
Old 06-07-2007, 05:01 PM   #7
ROCNDAV's Avatar
I went with the big bore cometics on my build too.
ROCNDAV is offline   Reply With Quote
Old 06-07-2007, 05:25 PM   #8
speedracer5532's Avatar
.040 Cometics with 4.160 bore, got them from AFR.
speedracer5532 is offline   Reply With Quote
Old 06-07-2007, 06:13 PM   #9
ninetres's Avatar
So they don't work?
What the **** head gasket should I run, lol????????
So confused.
Old 06-07-2007, 06:23 PM   #10
ABeasst's Avatar
I run GM MLS.
ABeasst is offline   Reply With Quote
Old 06-07-2007, 06:24 PM   #11
DanZ28's Avatar
So they don't work?
So confused.
Seems the LS7 gaskets are working fine (4.125). I think Tony from AFR recomended them...
Dan
DanZ28 is offline   Reply With Quote
Old 06-07-2007, 06:35 PM   #12
JMBLOWNWS6's Avatar
I went with felpro because that what Kurt reconmended!
Old 06-07-2007, 07:53 PM   #13
Tiago's Avatar
felpro release the 6 bolt gasket yet?
Old 06-07-2007, 07:55 PM   #14
mr2guru's Avatar
SCE titans ICS...
AFRs are 4.080 on the chamber IIRC so you'd need at least a .020 greater gasket as those need .010 backspacing from the flamefront.
mr2guru is offline   Reply With Quote
Old 06-07-2007, 08:12 PM   #15
SCE Titan ICS are JUNK!
Old 06-07-2007, 10:11 PM   #16
Navy David SS's Avatar
Large bore .040 Cometics.
David
Navy David SS is offline   Reply With Quote
Old 06-07-2007, 11:41 PM   #17
helicoil's Avatar
Default 6-bolt gasket
Quote:
Yes, they have. I can get the part number next Tuesday when I go back to work.
helicoil is offline   Reply With Quote
Old 06-08-2007, 10:02 AM   #18
Quote:
is this based on personal experience ?
Ive bought a set, but havent needed to use them yet.
Im on stock GM MLS at the min, have been for over a year with no problems.
stevieturbo is offline   Reply With Quote
Old 06-08-2007, 02:50 PM   #19
Yes it is based on personal experience. I have yet to see a set that didn't leak coolant.
Old 06-08-2007, 05:24 PM   #20
Tiago's Avatar
Quote:
cool, let me know
Tags
225, 4125, afr, copper, forced, gasket, head, induction, ls1tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
