ive got belt slip, should I go sdce?
im running a reichard racing ultra grip pulley but I still have some slip unless I tighten the crap out of the belt to the point where im damaging the belt. what do you guys know about the sdce setup? or any other suggestions.
The RR pulleys are known to be an "OK" fix to belt slip, mainly they just chew up belts as you already see.
The set up you speak of has proven itself time and time again here on tech. It is a spring tensioned 8 rib pulley set up that will put an end to your belt slip problems and get you making big RELIABLE boost in no time. Belt life is also increase substantially as well.
I ran it and now its on Kp's TA and he has had nothing but great success with it too.
J
J
