Help me pick pistons/rings/rods
A little background info..
Car is a 2004 GTO with the GEN TTR TWIN TURBO kit.. Cam is a 220/224 581/581 112+4
Well I am pretty sure My motor is toast.. Gave her hell last night at the track and she did fine but today I was putting around town and it went super lean in 1 bank.. Started pusing oil out the breather..Backfiring and barely accellerating.. So its time to yank her out and build it right.. Its been smoking for a good bit anyhow.. So I knew the rings where on the way out..
What I am thinking is some nice forged pistons something that will give me about 9.5:1. Some rods that can withstand about 900 RWHP. And of course the best rings I can find that will take the power as well..
I plan on using my stock ls1 block and the stock heads.. I might buy some 243 castings to throw on there since they have to come off.. Undecided on that.. I allready have a cam that I like so Thats going to be the same as well.
I am far from an engine expert especially when it comes to one that needs to withstand atleast 18-20 lbs of boost.. Any input or help would be appreciated.. Iv done a ton of searching and there is some good info out there but nothing specificalyl for my application.. My car is an 04 so it is an LS1
Thanks in Advance..
__________________
Thanks in Advance..
__________________
Robbie.....
Eagle H-Beam rods will work just fine and you can get them all dat for $499
The diamond -8.6cc Dish pistons for a 3.905" bore will work just fine.... Those should be around $600.
Id just then use some 12 point ARP head studs, main studs and some MLS gaskets and you should be fine.
Id add a new ported oil pump and double timing chain while u were at it.
Kyle
Kyle
Originally Posted by robul
what kind of rings do you think kyle? This it would be worth it to put on a set of 243 castings as well?
I already had a set of Ported and Polished 5.3 heads, and since not going rediculous with boost (14psi) I decided that 9.0:1 CR was going to be ok... down the road i may get a different set of heads if i feel like i want to turn up the boost...
However, with the smaller chamber heads, i chose Mahle -16cc forged pistons... eagle ESP H-beam rods with ARP L19 bolts... Just using the rings that come with the pistons...
wiht that kind of boost, i'd say a set of 6.0 heads and the -16 cc heads would probably get you down in teh low 8's CR... which would be a good idea.. that's gonna make a hell of a lot of power
FYI Robbie the L19 rod bolts arent worth the $$ if your not going to spin the motor to 7500+ rpm's....
We used Hell fire rings last time and ill get back to ya on the rings im using this time.....
I agree with picking the heads 1st and then specing the pistons.
The LS6 243's blow awsome untouched and just add some awsome springs and u should be good buddy.
Who's building the motor???
Hit me up on AIM when ya see me....
Kyle
Kyle
