oil in turbo- hot and cold side
I am running an APS twin turbo kit on my 05 GTO which uses Mitsubishi 20G turbos and I have had issues with it smoking when I jump on it as long as I can remember. There is oil in the compressor side and coming out from between the center section and turbine housing on the passenger side turbo and some on the drivers side also, just not nearly as bad. I can't see it being a bad turbo on both sides like that, so I'm leaning towards it needing a restrictor. This kit does use a scavenge pump, so I'm thinking it is just too much oil.
Problem is, I do not know how much restrictor to use- I do not want to kill the turbo. It is pulling oil from the pan right above the oil filter and has one feed line to each turbo. If I put a restrictor in, should I just put on in right at the distribution block (before the outlets), or is it better off as close to the turbo as possible?
Any advice on what to do here? Also, the drivers side has some oil as well, just not as bad- I'm thinking it has something to do with the scavenge pump setup .
APS said it could be from my breather since I am not running a catch can, but I have never seen oil in the intake stream come out the hot side like that and just don't see how it is possible.
Any help would be appreciated.
Joe
Joe
I can tell you from experince, if your engine is not vented well enough,you will suck oil past your ring's and into the exaust side and intake side. It also came out of my wastegate dump's onto the driveway. 2 small puddle's of oil. It happened to me on accident while I was cleaning my engine and forgot to take the cap off of the breather tube on the passenger valve cover. Looked like a freight train till i got it burned out!!
Wow, never seen that one before. I am running just the two 3/8 valve cover breathers that go to the turbo inlet pipes along with a PCV/check valve in the lifter valley, though it is only at idle and cruise, not under boost obviously. I was going to put a breather cap on the passenger valve cover (oil fill breather), but APS has the oil return going into the valve cover at the base of the filler neck and I assumed it would only blow the oil up from the return and out the breather.
The smoke is only when I initially get on it, then it clears right up, which has me doubting it is anything with the rings.
Make sure your oil can get out of the turbo. If you have blockages it will back up in the turbo and can go into both the hot and cold side.
Put a seperate restrictor in front of both turbos (as close as possible). Start at like 0.100"/side, if you get into the 0.060" range try to make you drain better. Smallest restrictor I have heard someone using was 0.040".
Ensure your PCV system is either breathing to the atmophere (do not pressurize the crank case), or even better, run them to the air inlet of the turbo/s (so when the engine goes into boost the PCV lines and crank case have a vacuum - this will make your intake dirty over time if you are not running a catch can).
I'll know after I do more driving tomorrow if it is truly gone or not- I only got to get on it a couple times before dark today.
If it still smokes, I'll be adding a restrictor. Thanks!!
Joe
