the beef is finally here....
Old 06-27-2007, 04:39 PM
red beast's Avatar
Talking the beef is finally here....
my turbo came in yesterday and still trying to get it to fit...alot of cutting and the down pipe needs to be lengthened some...here are some pics...
Old 06-27-2007, 04:55 PM
6techniques's Avatar
awww, look at the little baby spooler!
Old 06-27-2007, 05:42 PM
red beast's Avatar
can't wait to get the damn thing running.....
Old 06-27-2007, 06:02 PM
post up LOTS of pics and vids when you get her up and running, good luck!
Old 06-27-2007, 06:07 PM
red beast's Avatar
thanks, I will......
Old 06-27-2007, 07:11 PM
HUNTER02SS's Avatar
What did you do,get the smallest turbo you could find!!
That should be fun.
Old 06-27-2007, 07:13 PM
smokinHawk's Avatar
nice which one is it?
you gonna use any airfilter?
Old 06-27-2007, 08:47 PM
ninetres's Avatar
+1
What turbo is that?
Old 06-27-2007, 09:34 PM
Josh@KY-Turbo's Avatar
Originally Posted by ninetres
+1
What turbo is that?
+2. What turbo are we all looking at?
Old 06-28-2007, 03:30 PM
red beast's Avatar
garret GT-4508r and we plan on using an air filter, but we might have to fab one up because of the location...
Old 06-28-2007, 03:48 PM
Specs I found:
Compressor
Wh Dia Trim A/R Ind Exd
80.8mm 108.0mm 56 0.69
Turbine
Wh Dia Trim A/R Type
87.0mm 85 - -
A/R's available: 1.01, 1.15, 1.28, & 1.44
Ball Bearing Unit.
Compressor MAP:
Old 06-28-2007, 03:52 PM
LS1TECH Sponsor
DrTurbo's Avatar
Nice looking turbo and will spool well, but the turbine wheel is a horrible piece for a performance turbo. 12 blade design is going to cause some serious back pressure problems. Plus the turbine is only about mid 60% efficiency.
We have some customers that have used that unit on 300-400ci builds and have not been happy with the logs on backpressure. Keep in mind the GT42 turbine wheel flows about the same and does this at 74% efficiency.
Old 06-28-2007, 04:42 PM
red beast's Avatar
I will keep an eye out for any issues, if the 12 blade doesn't work well for some reason I will change it or upgrade the turbo...I'm looking for very quick spool 3000-3500 (which garrett claims it will do it) and I'm shooting for 1K which it should be able to support that also...if it meets these goals then I will be a happy person, if not back to the drawing board..I'll see in about 2 weeks when I get it tuned...p.s. will backpressure increase or decrease the larger and better flowing the motor???
Old 06-28-2007, 05:03 PM
LS1TECH Sponsor
DrTurbo's Avatar
Back pressure will rise with larger free flowing engine and boost pressure will drop.
Old 06-28-2007, 09:16 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
What made you decide to put it there? That seems like an awful position for it.
Old 06-28-2007, 10:37 PM
transam5.7lt1's Avatar
Is it sponsored by the Coca-Cola Company??? j/k! It looks good!
Old 06-29-2007, 08:50 PM
red beast's Avatar
alot of kits put the turbos there, more room and you can keep the a/c which is nice because it's a street car....
Old 06-29-2007, 11:56 PM
OWN3D BY MY PROF!
Have any pics of Fbody single turbo kits with a turbo like that? I've never seen anyone cut out a huge chunk of their fender like that. Just seems a little ill concieved. You're obviously going to have to do some sort of tubular manifold / custom crossover.
Why not just put it in the middle and run the downpipe like PSJ has on his setup? That minimizes the hacking necesitated to fit the turbo / downpipe and would still allow you to maintain your AC.
PSJ's downpipe:
Old 06-30-2007, 07:56 AM
KraZy's Avatar
Beautiful!
Old 06-30-2007, 10:23 AM
BlackySS13's Avatar
Both of those are interesting setups.
Quick Reply: the beef is finally here....
