Gen-TT Truck Twin Turbo Kit
Old 07-06-2007, 05:32 AM
bluecamaroz28's Avatar
Default Gen-TT Truck Twin Turbo Kit
Who's interested in a Gen-TT Truck Twin Turbo Kit?
How would turbos be best placed, underhood or similar to F-body kit?
What turbo size would be good for torque down low?
Share your views.
Old 07-06-2007, 05:37 AM
Mr_president's Avatar
T76 GTS and my buddy happens to be selling one . good power down low and high...
Old 07-06-2007, 05:53 AM
Twins won't go that big as T76.
Twin GT37's or T60's turbos maybe.
Old 07-06-2007, 06:02 AM
Street Tuna's Avatar
Our twin kits are all about BIG TORQUE
We have done them for the Aussie trucks and they are a decent hard running thing
Old 07-06-2007, 06:18 AM
Where are the turbos going to be placed?
Old 07-06-2007, 06:45 AM
High in the engine bay I would consider in the trucks, there is plenty of room from our initial engineering evaluation
Old 07-06-2007, 06:48 AM
chuntington101's Avatar
are they in a similer position to the GTO kit???
thanks Chris.
Old 07-06-2007, 07:46 AM
Yes they will be mate
Truckers got to see each others turbos
Old 07-06-2007, 11:19 AM
BlackySS13's Avatar
There's so much room in the engine bay, you could do whatever you want.
Check out my build.
https://ls1tech.com/forums/forced-induction/741491-03-silverado-ss-76mm-build.html
Old 07-06-2007, 04:18 PM
Ok going Truck Shopping today.....
Got my eye on an 05 Silverado 5.3 litre. Is this the right choice?
Truck guys please feel free to chime in
Old 07-07-2007, 07:32 AM
Not bad at all.
Does it have electric cooling fans or clutch fan?
Old 07-07-2007, 04:16 PM
Which do I need?
Old 07-07-2007, 05:21 PM
TT-TECH Veteran
Inspector12's Avatar
I believe most of the trucks have the electric fans now I don't know what the 05 has (I think it is electric.) although it isn't a big deal as they are cheap enough to buy and install if they are needed JMO.
Old 07-08-2007, 12:00 PM
Electric fans will give more room for the turbos but as said swapping to electric fans is easy.
Old 07-10-2007, 04:10 AM
Heres a couple of photos of an Aussie truck with one of our kits in place that belongs to the owner of a famous Texas/Aussie clutch manufacturer. Its known as a Holden Cross8 and is a 4 x 4 LS1. With our kit and everything else stock it ran a 12 second pass at 115mph
With only a couple of minor changes this will go onto your trucks
All you can see from the outside is the shiny front mount intercooler. Believe it or not this vehicle does most of its work towing Australias fastest supercharged LS1 around the country to drag meets....oh the irony of it!
As you can see everything under the bonnet is a nice, neat and professional fit that you can carry out on a DIY basis
A picture of the Gen-TT kit on the engine stand shows the basic layout and how it comes together
Old 07-10-2007, 08:16 AM
BlackySS13's Avatar
I believe most trucks switched to electric fans in 04. Mine is an 03 with a clutch fan, but I bought a set of 04 efans on ebay cheap. It'll definately add quite a bit more room to work with.
Old 07-10-2007, 08:42 AM
Martin,
Is the project truck RH or LH drive? It will make a difference with US trucks since the steering stuff will be LH.
Old 07-10-2007, 04:43 PM
All our engineering is based on LHD these days, so no problem there
Quick Reply: Gen-TT Truck Twin Turbo Kit
