what does everyone run for crank ref deg on bigstuff3?
Old 07-08-2007, 12:16 AM
Boostaholic's Avatar
Default what does everyone run for crank ref deg on bigstuff3?
What is your crank reference degrees in bigstuff3?
The way we figured out our TDC was probably wrong.
Also - what does cam ref deg do vs crank ref deg?
Old 07-08-2007, 12:22 AM
kp
kp's Avatar
Mine is at 348.5, I checked my TDC with the head off and tried two different timing lights so its pretty close I think. Last car I did with a lunati crank was right at 350.
I dont see cam reference anywhere.
Old 07-08-2007, 12:30 AM
I just checked and I have really old software, the newer software has two sections for crank ref deg
One is COP, the other is crank trigger
What are you using for the COP one?
Old 07-08-2007, 12:46 AM
kp
kp's Avatar
348.5, I dont think the crank trigger one does anything on an LS1 box.
Old 07-08-2007, 01:05 AM
whynot's Avatar
we are at 345 degrees
Old 07-08-2007, 04:41 AM
TT-TECH Veteran
Inspector12's Avatar
354 for me COP is what I am using I am with KP on the trigger.
Old 07-08-2007, 08:04 AM
MIGHTYMOUSE's Avatar
just above the cop box there is a static test timing box. fill it in with something and then check the box.
then put a timing light on the thing and change the cop value until the numbers match
this assumes you have a degree incremented and tdc marked damper and a pointer
my last engine was 20* behind this one
Old 07-08-2007, 12:11 PM
kp
kp's Avatar
My firmware must not be new enough, the static timing doesnt work on mine
Old 07-08-2007, 01:04 PM
i havent done it that way either, i figured thats why he added that feature though.
select a bunch of cells around idle and move it to the same amount then
Old 07-08-2007, 01:10 PM
kp
kp's Avatar
I just have a timing cal I load in with the timing all the same and idle at 2500rpm, you have to zero out the idle timing correction also and its easier to just load a new file then change everything then change it back.
Would ne nice if the static timing worked, my firmware is over a year old, may not even work with LS1 firmware at all..
Old 07-08-2007, 05:50 PM
TT-TECH Veteran
You need to go download the latest version of BS3 off of there website. Iam still using the older one I downloaded it to a CD and just haven't loaded it to the car etc...I had to change the whole timing table to do mine, but not a big deal.
Old 07-08-2007, 07:32 PM
kp
kp's Avatar
I have the newest software but the static timing doesnt work, not sure if its firmware (mine was updated last year) or if its just not active on the LS1 firmware at all. Really not a big deal
Quick Reply: what does everyone run for crank ref deg on bigstuff3?
