Vortech 7" Crank pulley
Old 07-10-2007, 01:14 AM
Evaporate's Avatar
Default Vortech 7" Crank pulley
Will a ASP 7" Crank pulley for a Mustang Fox body fit an LT1 Fbody with a vortech S-trim?
Old 07-21-2007, 07:39 PM
jegan1989's Avatar
it is just a pully man check the rib on it and then on your damper and you will know if it will work or not just as long as the pully is for a vortech set up which i am not to well in vortechs i know procharger and if it is set up the same way as a procharger then the pully will work just as long as the rib is right
