Journal Bearing vs. Ball Bearing Turbos
so what's the deal with these types of turbos? is the added reliability of a ball bearing turbo worth the cost for just a street car? or will a journal bearing turbo hold up just fine? what kind of differences will you see between the two on the track?
I road race journal bearing turbos. A journal bearing turbo can last the life of the engine. I've had at least two I know of over 40k miles before they were sold to someone else. My journal bearing T76 reaches full boost around 2200 rpm. *I* feel like a journal bearing turbo is perfectly suitable for most applications and the money could be better spent elsewhere unless your budget is high for your build. Not cracking on ball bearing centers, just stating facts based on my experience.
i'm afraid that my budget isn't that high, but i wanna do things right the first time so my system has excellent longevity. i was looking at a 67mm turbo. not gonna be roadracing, it's gonna be in a street car that'll see the track here and there. doubt i'll even go over 10lbs of boost. speaking of which, will anything more than 8 psi require methanol injection or an intercooler, even with 6.0L heads? on stock internals, mind you.
Well...the BB is nice for transient boost situations...that is where is really shines, but we are only talking a couple hundred rpm.
The downside to the BB is the cost of a rebuild. A local shop cannot rebuild them, they must be sent to the manufacturer (Precision in this example) and it will end up costing you 750-800 dollars to get fixed.
Compare that to a regular JB, which can be repaired by a local guy for 200-250.
We prefer JB here at the shop, but each one has its +- ... for the money and easy of downtime repairs, JB is the way to go.
Originally Posted by Zombie
In the case of very large turbos on small engines... you forgot that part.
Dual BB is nice if you have the extra money to spend. Is it worth it???....well that remains to be seen. Also Garrett DBB's can not be rebuilt, as they have to be replaced as a whole CHRA through exchange cause we offer that service here, which is the same as PTE and others. As for the T-netics BB, it can be rebuilt easily, so its probably the best setup to go with if you need BB and want the ease of rebuild. As for the difference....well on most of the big ci engines.....maybe 200-400rpms max and only in the mid boost...from say 3500-4500 range. In the lower and higher rpms their is virtually no difference at all and unless you analyze a log of boost versus rpms, you would never know it.
I completely agree, that you really wouldn't notice the difference unless analyzing logs.
You forgot about Innovative's DBB CHRA's being rebuildable for cheap, but their service has gone to the ******* unfortunately. I would not buy another one of their turbos unless they got their act straight with service.
ok so now the only thing i'm wondering is, if i get a 67mm sts and push 5-9 lbs of boost with 6.0L heads and meth injection, is my motor gonna blow, or perform reliably? can you even make a turbo setup run reliably?
Turbo's will run very reliable if tuned properly. Also I tell folks, go with a slightly larger turbo like a 76mm on a LS1. The larger units come on a tad later and help keep cylinder pressure down.
well i was thinking of running methanol injection but i don't know if an FMIC is a better idea or whatnot all i know is the meth kit is half as expensive and the juice itself is cheap. that and i've been told it's better than FMIC.
I run both. I know it's not required but I want a safe setup. FMIC is always there. I know it's pricy and not something you need today but i would definitely put it on my mod list. Some have not purchased the STS FMIC because they are pretty pricey and made/bought a different unit and saved a few hundred bucks along the way.
