What grade of oil are the you guys using-15psi and over?
Old 07-15-2007, 08:37 PM
eb02z06's Avatar
Default What grade of oil are the you guys using-15psi and over?
Tried to search this but I wasn't so successfull. i'm just wondering what grade of oil you you guys are using on built motors that are pushed hard and making lots of boost.
Thanks!
Old 07-15-2007, 09:00 PM
HUNTER02SS's Avatar
Castrol 5w-30.
Old 07-15-2007, 09:03 PM
Tom@SpeedInc's Avatar
Valvoline VR1 20w50
Old 07-15-2007, 09:18 PM
cablebandit's Avatar
rotella t
Old 07-15-2007, 10:58 PM
TT-TECH Veteran
Inspector12's Avatar
!0w-30 in Texas!
Old 07-15-2007, 11:02 PM
7 Second Club
ty_ty13's Avatar
Originally Posted by Fraser@SpeedInc
Valvoline VR1 20w50
x2
Tyler
Old 07-15-2007, 11:15 PM
Blownramair's Avatar
mobile 1 -- 15w50 in the motor city
Old 07-16-2007, 12:41 AM
Zombie's Avatar
20w50.
Old 07-16-2007, 12:47 AM
mahhddgtp's Avatar
Why the higher front number? Isn't that a little thicker oil?
Higher temps?
Old 07-16-2007, 07:49 AM
Tiago's Avatar
Ive always used 15W50 but I am researching and may run something else in new motor.
Old 07-16-2007, 08:21 AM
kcmags's Avatar
Royal Purple 10w30
Old 07-16-2007, 08:53 AM
LS1Tech Sponsor
Slowhawk's Avatar
The same oil we run with under 15lbs. Ussually Mobile 1 0w/40.
Old 07-16-2007, 12:01 PM
Zombie's Avatar
Higher temps?
Yup, nothing like hot lapping the car in 105+ temps. I'll give it a break after 3 passes though to let it cool.
Old 07-16-2007, 12:05 PM
NoGo's Avatar
10w 30 or whatever else is in the garage... I think I had some 10w40 lying around for this oil change.
Old 07-16-2007, 12:13 PM
kp
kp's Avatar
whatever decent oil is on sale, penzoil, valvoline, castrol etc. 10w30 in the winter and 10w40 in the summer, I change it pretty often though.
Old 07-16-2007, 01:16 PM
SuperZ's Avatar
15-50 Mobile 1
Old 07-16-2007, 02:27 PM
LS1TECH Sponsor
DrTurbo's Avatar
Rotella 10W-40
Old 07-16-2007, 02:37 PM
Mekkadon's Avatar
is synthetic a must? Just trying to save some money.....i've been using Mobil 1 10W-30
Old 07-16-2007, 02:44 PM
TS6
TS6's Avatar
I'm with KP here, I just use a good name brand oil and change it often. I generally use Valvoline because I know someone who used to work for them and they actually said that they buy the best crude (or whatever) and make the best oil. I run 10W40 all the time, but I don't drive the car much in the cold weather.
Old 07-16-2007, 02:49 PM
NA$TY-TA's Avatar
Same here Kev..... i change it quite often.....
Quick Reply: What grade of oil are the you guys using-15psi and over?
