What pistons are people using?
Old 07-18-2007, 01:06 PM
black98ws6ta's Avatar
Default What pistons are people using?
Does anyone use a on the shelf piston in a 900+ rwhp application? I know the questions sounds dumb but it seems like people make big power on shelf parts.
Old 07-18-2007, 04:00 PM
cablebandit's Avatar
wiseco..I asked Brian Nutter for a piston for 1000rwhp and their off the shelf piston/rings "no problem"
Old 07-18-2007, 07:04 PM
topfig1's Avatar
Wiesco custom blower pistons from LME here.
Fig
Old 07-18-2007, 07:28 PM
ssdriver27's Avatar
wiseco 2618s here also from LME
Old 07-18-2007, 07:48 PM
NA$TY-TA's Avatar
Made over 1000rwhp with off the shelf Diamond -15cc dish pistons. for 6.125" Rod and stock crank.
Going with a Custom set of JE's this time..
Kyle
Old 07-18-2007, 07:50 PM
mahhddgtp's Avatar
Honestly I'd go with Wiseco most likely. What sort of application is this for? You may want to investigate what material is in your piston..
https://ls1tech.com/forums/archive/i.../t-461396.html (Brian Nutter is in this thread)
https://ls1tech.com/forums/forced-induction/591175-piston-pick-one.html
Old 07-18-2007, 08:18 PM
HUNTER02SS's Avatar
I am running Manley dish piston's for my setup.
Old 07-18-2007, 09:12 PM
Texas Heat's Avatar
Im looking at wiseco's...
Old 07-18-2007, 10:11 PM
LSInnovations's Avatar
I have some W2W Mahles 2918 alloy..
Old 07-18-2007, 11:17 PM
My problem is time vs the best part for the job. Diamond reccomends a custom piston at 900rwhp-1000rwhp, but I wanted to get out and have fun with the car so I was wanting to find a on the shelf stocked piston to save time. In the end I filled out a custom diamond piston sheet and took care of it.
Old 07-18-2007, 11:18 PM
Mekkadon's Avatar
ross dished pistons
Old 07-19-2007, 02:02 AM
Blownramair's Avatar
yeeaaaa buddy... mahles here too... 700 @ the rubbers
Old 07-19-2007, 07:04 AM
slowbrakiller's Avatar
going to run diamonds
Old 07-19-2007, 07:05 AM
SonofaBish's Avatar
Mahle forged, -16cc dish
Old 07-19-2007, 12:22 PM
Josh@KY-Turbo's Avatar
+1 for the above.
Old 07-19-2007, 12:40 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Diamond -15cc ( 4" bore x4" stroke ) with thermal coatings.
Keith
Old 07-19-2007, 12:41 PM
DONT get the Mahles that are made of the 4xxx ( i forget the number) material...its too brittle for FI and ANY detonation.
Old 07-19-2007, 12:42 PM
mahhddgtp's Avatar
Mahle 4032.
Did you have a set?
Old 07-19-2007, 02:02 PM
not anymore...broke the ringlands twice with no detonation (approx 800rwhp...12deg timing 11.0a/f and c-16)...the area is THIN where the top land meets the piston. My wisecos next to it are like an anvil next to aluminum foil. these were 402 stroker/boost pistons. A Sponsor has had the same issue as well but i will let them tell their tale if they want
Old 07-19-2007, 02:07 PM
mahhddgtp's Avatar
Yet another reason I'll be a Wiseco guy
Quick Reply: What pistons are people using?
