APS F body reinforced MAF delete hose
Old 07-18-2007, 09:36 PM
peter@aps's Avatar
Default APS F body reinforced MAF delete hose
Guys, Here's the first pic of the APS F body twin turbo system MAF delete hose, this part will be released by the end of Sept 07 if all goes to plan. Do you guys like the steel reinforcement rings on ther MAF delete hose? This will ensure that the moulded 4 ply nomex reinforced silicone hose can cope with quite high boost pressures. Pm me if you'd like to order a MAF delete hose as I only have very limited numbers.
Peter
http://www.airpowersystems.com/fbody/maf_d_1.jpg
Old 07-18-2007, 09:44 PM
99Z28LS1's Avatar
i love the stuff that has yall's name on it. everything looks amazing APS, great stuff
Old 07-18-2007, 10:14 PM
Mr.MartyStone's Avatar
how much?
Marty
Old 07-18-2007, 10:22 PM
waterbug1999's Avatar
Is that the same as these?
nonsponser url
edit by mod: yes they look very similar.
Old 07-19-2007, 12:26 AM
wildta's Avatar
Does the APS kit not work woth a MAF ?
Old 07-19-2007, 12:38 AM
Brains's Avatar
I'd love if it that was in the kit, I imagine most of us won't be running a MAF
Otherwise, I'll probably just end up with a chunk of 3-1/2" steel tubing painted black..
Old 07-19-2007, 06:56 AM
smokinHawk's Avatar
on the intercooler were you guys use the rubber groment IAT sensor, is it able to be tapped for the threaded IAT? also what is that other boss above the iat for?
Old 07-19-2007, 08:23 AM
bluecamaroz28's Avatar
Looks great. What material?
Old 07-19-2007, 05:46 PM
peter@aps's Avatar
Many thanks for those kind words and I'm really happy with the F body MAF delete hose, should make APS twin turbo system customers happy to have this option.
Peter
Old 07-19-2007, 05:49 PM
peter@aps's Avatar
The twin turbo system is designed around using the MAF...............this MAF delete connection hose is simply an option for those who'd like to go with a SD tuning approach.
Peter
Old 07-19-2007, 05:52 PM
peter@aps's Avatar
That'll will work...............though make sure you use stainless steel as you don't want any surface rust form a mild steel connection pipe entering the engine.
Peter
Old 07-19-2007, 06:07 PM
rice4eatingnotdrivin's Avatar
i completely agree.. the last thing u need is a chunk of rust going in the intake... plus stainless is a lil easier to shape.. but it warps real easy when u tig weld it.. try to use 1/8" if u go to make one
Old 07-19-2007, 06:25 PM
peter@aps's Avatar
I guess you could tap the intercooler top tank casting for a threaded IAT sensor and the other 2 bosses can be tapped for either Meth injection nozzles or boost ports.
Thanks,
Peter
Old 07-19-2007, 06:58 PM
calongo_SS's Avatar
Those bosses are not going to come tapped? It looks like they are tapped & plugged in the pic. Is that just a prototype piece? It'd be nice if they came tapped for an M15 meth nozzle.
Old 07-20-2007, 01:16 AM
peter@aps's Avatar
No, We don't tap the end tank casting.................this way guys can tap the casting to what ever thread they need or require.
Peter
Old 07-20-2007, 08:29 AM
7 Second Club
ty_ty13's Avatar
Peter
very smart move....
Old 07-21-2007, 03:37 AM
JMBLOWNWS6's Avatar
Man this should come with the kit! Dont send me the maf hoses, send me the SD hose. But a 90 mm version
Old 07-22-2007, 05:46 PM
peter@aps's Avatar
4 ply Nomex reinforced silicone with external steel support rings for additional strength at high boost pressure.
Peter
Old 07-23-2007, 10:04 AM
Fastbird93's Avatar
Peter.....
Have you considered doing one of these MAF delete hoses for the C5 crowd?? I have a 2 Bar SD tune in my car but I still have the MAF fuglying things up.
Old 07-23-2007, 05:25 PM
peter@aps's Avatar
Originally Posted by Fastbird93
Peter.....
Fastbird, A speed density upgrade kit will will be released in the future for the C5 Corvette.
Peter
Quick Reply: APS F body reinforced MAF delete hose
