Velocity rings for Superchargers-gain 1 to 3 psi?
Old 07-27-2007, 09:25 AM
eb02z06's Avatar
Default Velocity rings for Superchargers-gain 1 to 3 psi?
Has anyone heard anything about these:
http://www.reichardracing.com/velocity_ring.php#
It's a velocity ring that goes in the inlet side of the supercharger-it supposed to raise boost levels by 1-3 psi without spinning the blower any faster.
It would seem to be nice effecient way of getting a bit more boost out of the blower.
Old 07-27-2007, 09:32 AM
Speed's Avatar
I'd have to see it to believe it. I'm guessing those claims are based on the removal of the air filter more than the installation of that ring.
Old 07-27-2007, 02:23 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
it has to do with air turbulence if you decrease the turbulance you increase the flow and efficiency of the of the blower. Same way that velocity stack in ITB setup can change the hp/tq curve by lengthening or shortening the stack.
Old 07-27-2007, 02:26 PM
WarShrike's Avatar
I'd like to see difference in air filter off w/ and w/o the ring installed.
ITBs, such an interesting thing in the racing world that can make or break some people
Old 07-27-2007, 05:03 PM
DeltaT's Avatar
My inlets on the S-trim and T-trim Vortechs have already been shaped like that, so I thinking that another one strapped on won't add anything. Might not hurt but I can't imagine a double flare would do much. Maybe if your blower had an untapered inlet?
Jim
Old 07-27-2007, 10:00 PM
NemesisC5's Avatar
Old 07-27-2007, 10:09 PM
mountainmagic's Avatar
gunna have to call BS
Old 07-27-2007, 11:07 PM
02NBMFormula's Avatar
boost is just a measure of air restriction
Old 07-28-2007, 12:49 AM
DeltaT's Avatar
Can you be more specific for this thread? Not sure what you mean regarding this device that fits on the intake side of the blower.
Jim
Old 07-28-2007, 04:13 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
if the blower is able to take in more air due to there being less turbulence then the boost will increase. Blowers have a set speed and do not bleed off boost like a tubo, the more air it can take in the more that it will compress.
Old 07-28-2007, 08:54 AM
NemesisC5's Avatar
If this is the case, have you thought about getting your blower inlet ported to smooth out the turbulanc like Tony Mamo, Cory Harris, and others do on LS2 throttle bodies ?
Old 07-28-2007, 09:08 AM
Got Me SOM's Avatar
wonder how much it is, i'd try it if it gave me 2 more lbs.
Old 07-28-2007, 09:12 AM
sevanseriesta's Avatar
I would try it to if the price is right......
Old 07-28-2007, 09:15 AM
NemesisC5's Avatar
I Agree
Old 07-28-2007, 09:33 AM
eb02z06's Avatar
I believe it's like $140, I saw them for sale on the NMRA Racing forums. I'm not sure if they work if there is any piping that goes infront of them. I'm also wondering about these mesh screens they run versus air filters-if that's a track worthy option or not. Those Renegade cars are sick, these guys make 30+ pounds of boost with a 8 rib belt using F1R's and Ysi's.
Old 07-28-2007, 11:26 AM
7 Second Club
ty_ty13's Avatar
yes but these guy change belts every pass...
Old 07-28-2007, 01:17 PM
eb02z06's Avatar
Nope not true-I talked to Bob Kurgan, Zoop Zelonis and the guys from Swill racing. With the proper tightening procedure they can get over 30 passes per belt.
You tighten the belt, make a pass and retighten-do this 3 times until the belt is fully stretched-it will stretch up to 2" according to these guys.
Old 07-28-2007, 01:34 PM
7 Second Club
ty_ty13's Avatar
the guys i've talked to said its one belt per pass...
Old 07-28-2007, 01:35 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
No the ren guys get more than one pass per belt, but they might be checking them pretty often.
Old 07-28-2007, 02:33 PM
Got Me SOM's Avatar
140 bux is kinda pricey, i was hopin it would be more like 80. I wonder if they have documented gains or are just saying it will work. By narrowing the path of the boost and smoothing the flow. I see it increasing velocity. Its pricey cause they are made from billet or something.
Quick Reply: Velocity rings for Superchargers-gain 1 to 3 psi?
