F-1A 427 l92 heads 219 cam 858 RWHP
Old 08-03-2007, 10:27 AM
corvettetimmy's Avatar
Default F-1A 427 l92 heads 219 cam 858 RWHP
I noticed a lot of discussion about L92 heads these days and made a post a week or so ago but it got locked because it referenced a for sale ad.
Anyway, the car is sold, but I wanted to share the dyno graph for those that might be interested in using l-92's for a high power build.
This was with 14psi boost 23deg timing and water/meth spray
12.0 Afr
The cam is a Dave's Total Performance 219/240 cam.
The heads were hand ported by DTP before assembly.
Old 08-03-2007, 10:32 AM
TN94Z's Avatar
Cool. My FI motor that I building will have L92s.
Old 08-03-2007, 01:08 PM
cablebandit's Avatar
nice numbers. it looks like the power falls off like you are out of blower. Is that the case?
Old 08-03-2007, 05:07 PM
1dirtyZ's Avatar
same question here, are you running out of blower or what?
Old 08-03-2007, 06:34 PM
LS1Tech Sponsor
Slowhawk's Avatar
Thats a Cam drop or possible valve float. 219 intake is small for a 427ci.NA it probly peaks hp at 4500rpm.
Old 08-03-2007, 06:35 PM
TNTramair's Avatar
running out of blower with an F1a??? strong!!
im gonna run stock l92's on my FI 402....just to see how' they'll do..
Old 08-04-2007, 02:55 AM
1dirtyZ's Avatar
interesting, lets assume intake duration was some where in the range of 230 or 240 on the intake , would the line be flatter or keep pulling up ? or would he run itno another restriction like the manifold?
oh and great numbers vettetimmy!
Old 08-04-2007, 04:25 AM
LSs1Power's Avatar
That thing need a larger intake duration
