8.6:1 347 with 14psi,any thoughts?
Old 08-07-2007, 05:38 PM
SPRAYED 01's Avatar
Default 8.6:1 347 with 14psi,any thoughts?
My goals with the car right now are about 600rwhp through a 3000k stall and 9 inch. Its a single turbo (presision 67) with fmic. Im going to run this turbo kit for a season just to get introduced to FI and then up grade to something alot bigger.
Is this compression to low for me now?
Alex
Old 08-07-2007, 05:58 PM
CHRISPY's Avatar
I think the comp is nearly perfect for pump gas but I'd go with a T76 at 14#s boost with those cubes and power level.
Old 08-07-2007, 06:35 PM
ninetres's Avatar
My results with 364ci (8.5:1) and a T76 at 14psi are in my sig. TH400 and 9" with a 3200 stall.
Old 08-07-2007, 07:07 PM
bboyferal's Avatar
That turbo may be the restriction?
Old 08-07-2007, 07:52 PM
SuperZ's Avatar
I know someone with that setup and they made 550ish rwhp.You mite need a bigger turbo for 600
Old 08-07-2007, 09:48 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
From reading over the years, my spidey sense tells me that you will run out of turbo before 600rwhp. Let it happen, and then upgrade. I'm sending you a pm on something else.
Old 08-07-2007, 11:45 PM
SPRAYED 01's Avatar
You know what im pretty much counting on that turbo running out of juice and upgrading to a 76mm. So everything things the comp is perfect considering ill probably upgrade turbo very shortly after?
Old 08-08-2007, 09:10 AM
CHRISPY's Avatar
I'd sell the turbo and pick up the T76 up front. Why waste time/energy installing/tuning a setup that you are going to change?
Old 08-08-2007, 09:13 AM
bboyferal's Avatar
Old 08-08-2007, 09:19 AM
BADDLS1SS's Avatar
I made 663 with a 10.0:1 347 with 14.5 psi out of a 76mm up front.
through a 2OTL exhaust and 12 bolt, in garbage air.
Old 08-08-2007, 10:15 AM
SPRAYED 01's Avatar
It wont cost me much more to tune it with another turbo later. I already have the engine,drivetrain, fuel to handle much much more. I like testing different things and im always changing setups. Its a part of life for me.
Old 08-08-2007, 08:08 PM
SSilverSSurfer's Avatar
sounds like my set up once its finished.
Quick Reply: 8.6:1 347 with 14psi,any thoughts?
