Calculating Compression Ratio
Ok I am lost here. Never really kept up with the info.
Here is what I know about my motor.
346ci
Diamond -8.66 cc dish pistons
Lunati pro mod rods 6.125 length
Stock crank polished
I am sure someone has did this before
The calculation for determining compression ratio works out like this:
CR=(D + PV + DC + G + CC) / (PV + DC + G + CC)
CR = Compression Ratio
D = Displacement
PV = Piston Volume
DC = Deck Clearance Volume
G = Gasket Volume
CC = Combustion Chamber Volume
http://www.circletrack.com/techartic...e_compression/
346ci
D = Displacement
PV = Piston Volume
G = Gasket Volume
346ci
D = Displacement
PV = Piston Volume
G = Gasket Volume
346ci
D = Displacement
PV = Piston Volume
G = Gasket Volume
Cam specs. 231/226 601/591 115lsa
Deck height. Stock LS1 Block
Head gasket std
Cylinder head volume; not sure what CC they are
Head gasket std
We need to know the CC of the head. Your going to have to find that out. Makes it alot easier
ok.
Enter Piston Dome Volume In CCs Negative For Dished Pistons (Use '-') -8.66
Compressed Head Gasket Thickness 0.021
Piston Stroke Length 6.125
Head Gasket Bore Diameter ?????
Cylinder Bore Size???? 4.030????
Bore/Stroke Designation Type
1 = Inches
Piston Deck Clearance Negative If ABOVE Deck (Use '-') : ???????
Heads are LS6 Patriot performance stage III Heads.
1 = Inches
maybe these will help
http://www.c5frc.com/calculators/Co..._Calculator.htm
or this
. http://www.rbracing-rsr.com/compstaticcalc.html
or this
What is the deck height on a LS1? Thats the only number I am missing
2cc, borestroke, calculate, comp, compression, designation, determining, diamond, forced, gto, induction, ls1, ls2, ratio, type
