50mm tial BOV what spring?
Old 08-17-2007, 08:09 AM
phildo's Avatar
Default 50mm tial BOV what spring?
My BOV is not working properly. I have the 11psi spring in it. My vacuum at a idle is 9-10. It shoots up to 15 when I let off the gas but the BOV does not open. If it is opening it is not fast enough because I can hear my turbo backing up. Do I go to the weakest 9psi spring? If I understand they way to pick a spring right than the 11psi should be working. What do you guys think?
Old 08-17-2007, 08:14 AM
cablebandit's Avatar
i had same prob....just trimmed one coil off at a time until it was right....i mean you will chunk the spring in the trash anyway so might as well try it
Old 08-17-2007, 11:11 AM
red beast's Avatar
mine done the same thing also, I called hp and they are sending me a spring that will leave the bov open all the time while in vacuum...
Old 08-17-2007, 07:26 PM
phildo's Avatar
Sounds good to me. Thanks.
Old 08-17-2007, 11:48 PM
JAvenger007's Avatar
Silver Spring: 12 PSI - (between -22 and -23 in/Hg)
Silver Spring: 11 PSI - (between -18 and -21 in/Hg)
White Spring: 9 PSI - (between -14 and -17 in/Hg)
Black Spring: 7 PSI - (between -10 and -13 in/Hg)
Im using the 9 psi currently. I haven't tried my 7psi or 11psi yet. I can't test because I can't put the car in boost (untuned on the meth), otherwise you could have my spares to play around with
Wouldn't the car just leak out of the BOV the whole time then during vacuum?
Quick Reply: 50mm tial BOV what spring?
