What size TB for carb intake w/elbow?
Old 08-19-2007, 08:32 AM
TT402LS1's Avatar
Default What size TB for carb intake w/elbow?
What size TB are you using on your 4bbl intake with elbow? I will be running an Edlbrock efi intake w/ elbow. The engine will mostly be street driven. (see sig) Havent decided yet on cam ( I was thinking 224-.580-114 )
Would a 90mm be too large??? Ant suggestions would be apprecited!
Thanks - Ron
Old 08-19-2007, 09:10 AM
Q8CamaRo's Avatar
running a stock ported TB wouldnt hold you back from anything, i`m going to put N/W 90mm TB with l92 carbed intake
Old 08-19-2007, 11:29 AM
TT402LS1's Avatar
I was thinking fo a Nick Williams TB, but I can only find 90mm's. I was also thinking of running a FAST 78mm TB. I guess what I want to know is will the smaller TB be better on the street? As far as throttle response, and/or touchiness??? What is everyone else running?
Thanks - Ron
Old 08-19-2007, 12:30 PM
NA$TY-TA's Avatar
Im running a Accufab 90mm TB.
Kyle
Old 08-19-2007, 01:53 PM
slowredz's Avatar
90mm Nick Williams here
Old 08-19-2007, 03:02 PM
TT402LS1's Avatar
How much street driving you do? How touchy is the thottle with a 90mm? Any tunning issuse with that size TB?
Anyone running a 1000-1300cfm 4 bbl TB? Pro's/ Con's???
Thanks - Ron
Old 08-19-2007, 04:46 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I am running a 90mm NW TB and an LS2 intake.
Old 08-19-2007, 07:34 PM
stevieturbo's Avatar
I agree.....although odd to read you arent sticking with stock size ??
FWIW, I switched from a stock LS6 intake and DIY ported TB, to a Carb intake, elbow and 85mm Accufab ( Ford ) TB....
I made fractionally more boost with the carb intake than I did with the LS6...go figure.
Stock TB flows enough for 1000+ in boosted form, that has been proven.
And given most plumbing is circa 3" OD....really, is there any need for a TB much larger than this ????
If most of the IC plumbing is 76mm OD, especially that leading up to the TB....what benefit can a 90mm TB offer ? ( the blade doesnt take up that much area )
Quick Reply: What size TB for carb intake w/elbow?
