Procharger Bypass Valve Question
Old 08-26-2007, 10:00 PM
2000LS1TA's Avatar
Default Procharger Bypass Valve Question
Hey guys, I want to replace my stock procharger bypass valve with a good one. What is the best one? Does it clamp right in the old ones spot? Also is it louder? Thanks, Ryan
Old 08-26-2007, 11:38 PM
WHPLASH's Avatar
I'd like to know also
Old 08-26-2007, 11:41 PM
D-Webz's Avatar
Dang man you have the set up that I want. What kind of numbers are you putting down.
BTW also interested in the bypass valve
Old 08-27-2007, 03:19 AM
BOONE's Avatar
I have the Procharger race ready, it is sort of loud but not that bad. I suppose it would be louder if I had more than 11 lbs to blow off. You can hear whine/air movement going down the road and especially across bridges and places with something to echo off of. You would have to weld in a flange and short piece of tubing to run it, somewhere between your blower outlet and your intercooler. Wherever you want or can fit it. It is vacuum operated and has a 3/8 port. Its also adjustable. If you do a search you will find pics. If I remember right the flange and gasket comes with it.
Old 08-27-2007, 05:41 AM
EPP
EPP's Avatar
The ProCharger race valve is indeed one of the best ones you can buy. Bob
Old 08-27-2007, 08:29 AM
WHPLASH's Avatar
Do you have this on your website? I only see the Vortech. Does this replace the stock one perfectly or do you have to change your hoses around?
Old 08-27-2007, 09:14 AM
2000LS1TA's Avatar
^^^My question too, I want a direct replacement
Old 08-28-2007, 06:42 AM
WHPLASH's Avatar
Bob????
Old 08-28-2007, 12:20 PM
2000LS1TA's Avatar
Old 08-28-2007, 12:37 PM
EPP
EPP's Avatar
Smile
Bob????
http://www.exoticperformanceplus.com...html?item=1261
Here you go, I have several more pic's to add. Thanks! Bob
Old 08-28-2007, 12:39 PM
2000LS1TA's Avatar
^^^Does that come with everything needed to just BOLT it in place of the old one??
Old 08-28-2007, 02:36 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
no, it can't be bolted on. You need to weld it onto a pipe. Mine is welded to my plenum as you can see here:
I painted mine black tho...
Old 08-28-2007, 03:15 PM
LS1Tech Sponsor
Slowhawk's Avatar
The car will probly have to be retuned after a race bypass to.
If you want noise,add a blow off valve.
Quick Reply: Procharger Bypass Valve Question
