Procharger guys what radiator are you using?
Old 08-30-2007, 12:52 AM
MonkeyBoneSS's Avatar
Default Procharger guys what radiator are you using?
Was curious to see what radiator you guys are running, stock or aftermarket?
If so what brand.
Old 08-30-2007, 01:21 AM
98turbls1's Avatar
I'm running stock right now but I want to go with a BeCool eventually...
Old 08-30-2007, 02:14 AM
mdhmi's Avatar
I ran a stock radiator with a D-1SC without issue. It was a conservative 500 rwhp street car setup.
Old 08-30-2007, 02:52 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
I use the Be Cool radiator. Pics are in this thread: https://ls1tech.com/forums/forced-induction/605648-solution-ati-heating-inpaired-cool.html
Old 08-30-2007, 05:21 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1228
We have been using the Ron Davis radiators in the C5 Corvettes with great success. I am sure their f body radiator shown above will also be just as good. Bob
Old 08-30-2007, 06:39 AM
JMBLOWNWS6's Avatar
Wow that is a badass rad. But dayum that mother is pricey!
Old 08-30-2007, 11:21 AM
There is a thread I was reading earlier about a guy converting to an LT1 radiator on his LS1 engine. I never really did realize how small the LS1 radiator is.
Are there any fitment issues with running a Be-Cool ?
Old 08-30-2007, 12:05 PM
Floader's Avatar
I use a griffin, but i have cut the core support out and tossed the A/C.
Old 08-30-2007, 08:01 PM
SSmokin 01's Avatar
Stock radiator with a shroud made out of lexan with one stock fan and one 12" low profile fan.
Old 08-31-2007, 01:38 AM
Blownramair's Avatar
600 bucks for my fluidyne... no problems with just under 1000hp
Old 08-31-2007, 05:00 AM
EPP
EPP's Avatar
Smile
Yes it is, but they make some of the best ones out there. Bob
Old 08-31-2007, 07:15 AM
moehorsepower's Avatar
Default radiator
Mine stock radiator with an 10" fan in front of it, 648 RWHP and sit all day in traffic with the ac on, never goes beyond 180 with only WATER and a bottle of Royal Purple Ice..
Old 08-31-2007, 08:59 AM
Chicago Crew UnderBoss's Avatar
I have a 02 vette Z06 and have 0 heat issues, and runs cool with stock radiator and the big intercooler that comes with my ECS D1SC complete kit, that I believe also came different radiator brackets to allow for the intercooler to fit, etc. See my sig. for details on my set-up!
Old 08-31-2007, 01:34 PM
koji777's Avatar
Becool
Old 08-31-2007, 03:07 PM
Ed Blown Vert's Avatar
I run the SLP radiator which is a LT1 radiator.
Old 08-31-2007, 04:18 PM
Spade's Avatar
You guys saying you run with the stocker and have no heat issues, I say come down to Florida and see were you stand. When I was in Belgium I did not have any problems with getting real hot but now that I am in the sunny state my temps are crazy. I am in the process of putting my LT1 radiator in right now so I will see if that helps.
Old 08-31-2007, 05:59 PM
Jake@EPP's Avatar
Jason, do you have the extra 9" fan on your shroud? We install these on most lower state shipout cars and kits. The 9" fan should be wired to turn on at the same time as the big fan. Also, the air dam on the front of the car is critical.
Old 09-03-2007, 11:20 PM
Spade's Avatar
No 9" fan yet. I am sure I will be doing that as well. Car does have the air dam still.
Quick Reply: Procharger guys what radiator are you using?
