Would changing my exhaust effect my tube (A/F)?
I had my car tuned with my 3" TD's and Dynomax Super Turbo mufflers, made great power. I have had clearance issues with it and couldn't get a DS loop in so I took it off and am running Moroso Spiral Flows strapped to the collectors with dumps. Obviously this is waaay louder and I ASSume it flows better. Should I be at all concerned that the increased flow will cause it to lean out? I mean, could it really flow all that much better than my other exhaust?
I would say it is most likely a little leaner. I would make a pull in 3rd or 4th which you should then be able to watch the WB.
We have seen approx 1/2 point difference on cars with similar setups as you explained.
yes i would say the tune is now off a little bit. on my sts kit, i removed the 90* charge piping that goes over the axle for a straight pipe, and the tune was off (lean) by a couple points at WOT due to more boost sooner. i would expect you to have similar results.
Originally Posted by TS6
So should this exhaust make a little more power then?
if the mufflers you had flow good I would not expect a HP gain
simply make a run in 3rd or 4th to verify your WOT A/F or hit a dyno to be safe
