Cant find 4" to 3" silicon 90 for turbo inlet.
Old 09-11-2007, 10:37 PM
SPRAYED 01's Avatar
Default Cant find 4" to 3" silicon 90 for turbo inlet.
Im running a precision 67 turbo. The inlet on the turbo is 4inchs. I need to attach some sort of piping to it with a filter at the end,just like every other car. Only problem is ive call like 5 speed shops and no one has ever heard of a 4inch to 3inch 90 degree bend silicon adapter. What is the deal, im sure others have run into this.
Any ideas?
Alex
Old 09-11-2007, 10:39 PM
JAvenger007's Avatar
PM'd you a site that sells them. $20 for 4ply 4" to 3" 90*elbow
Old 09-11-2007, 10:49 PM
OreoLt1's Avatar
http://www.racepartssolutions.com/categories.asp?cat=26
Hope this helps!
Old 09-12-2007, 05:17 AM
EPP
EPP's Avatar
Stylin Motors is who we use. They're more expensive, but theirs are 4 and 5 ply. Bob
Old 09-12-2007, 08:49 AM
smokinHawk's Avatar
why are you decreasing your inlet size? to you have constraints that limit a 4" intake tube or filter?
Old 09-12-2007, 09:02 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
Alex I have a 4" cobrahead part, it's bit big, I have all the parts in this pic except for the filter:
http://psj.ls1tech.com/gallery/main....&g2_itemId=265
Old 09-12-2007, 09:59 AM
CHRISPY's Avatar
intake hoses.com has it too. Why go 4 - 3 inch? Why not run a 4 inch diameter K&N?
Old 09-12-2007, 07:27 PM
SPRAYED 01's Avatar
The only reason for going to 3 was ground clearance and other clearance issues.
Old 09-13-2007, 10:28 AM
LS1Tech Co-Founder
Alex if you want to swing by on Saturday and grab the parts I have and see if they work for you let me know.
Quick Reply: Cant find 4" to 3" silicon 90 for turbo inlet.
