what mass air meter should i use?
Old 09-12-2007, 11:46 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
Default what mass air meter should i use?
doing a F1 Procharger on 347 inch LS with a FAST 90/90. was told to use a Z06 mass air meter. what has everybody else used for this type of setup and if the Z06 meter is good then what part#. local dealer is clueless without a VIN#.
Old 09-12-2007, 12:38 PM
MY99TAWS6's Avatar
Not sure if z06 is calibrated .Slp 85 would think would work ok.Lingenfelter now offers like a 100mm maf or something that they use on their big power turbo cars.
Old 09-12-2007, 01:03 PM
LS1curious's Avatar
I would go with either the 78mm 3 pin metal of the recalibrated and screened 85mm slp MAF.
Old 09-13-2007, 07:50 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Going with the SLP calibrated MAF will not get you much. The whole point of going with the ZO6 is that it can read the higher frequencies. The only reason to use the SLP is that one can plug in a 'larger' MAF without having to reprogram the PCM.
Keith
