need silicone 90 degree elbow
Old 10-07-2007, 01:17 PM
ZL1Killa's Avatar
Default need silicone 90 degree elbow
well you used to be able to search the sponsor list or view the total sponsor list...i either forgot how to do it or it has changed.
I need to fine a 90 degree elbow like what they give you in the STS kit (about 70mm) to bend from the piping to a 90mm throttle body. (101mm silicone end) and i need it in black.
from 3(about 7x mm) inch to 4inch (101mm)
Old 10-07-2007, 03:49 PM
SPRAYED 01's Avatar
siliconeintakes
Old 10-07-2007, 07:16 PM
trtturbo's Avatar
intakehoses also
Old 10-07-2007, 08:07 PM
ZL1Killa's Avatar
I'm only seeing one site that has a 3inch to 4inch 90 degree bend, everything else is just a 2.5ID or 3ID or 4ID piping....or am i losing it
Old 10-08-2007, 07:18 AM
smokinHawk's Avatar
there arnt to many pipes that are 2.75" (70mm)
are you sure you need a 2.5" one?
is that the size of the sts pipe?
Old 10-08-2007, 10:16 AM
anarchy99's Avatar
that siliconeintakes.com site has a ton of them. they even had the odd sized one that I needed from my a2w intercooler to 3.5 inch pipe before TB.
Quick Reply: need silicone 90 degree elbow
