Procharger guys with meth- what timing are you running?
Old 10-12-2007, 09:19 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Default Procharger guys with meth- what timing are you running?
I've had my meth kit on and been using it ever since I put the F1 on (still have the P1 tune when I wasn't using meth). I am going to be getting it tuned in a week and I'd like to know what timing everyone is running when using meth. Right now, I am at 20° and no KR. How much more (if any) should I go up from there? So for you supercharged guys out there using meth, what is your timing?
Old 10-12-2007, 11:43 AM
eb02z06's Avatar
Too many variables bro-but i'm running 16 degrees up top. Just make sure your knock tables are stock-FWIW I really only use the Alky to drop the inlet temps. They go from 120 to 70-80 degrees at 20 psi.
Old 10-12-2007, 12:02 PM
ChevyChad's Avatar
CR is 9.45, cam is 224/232 .581/.595 114+2, about 14.5psi from the F1 at abour 6500RPM, alkycontrol kit using 100% meth... what other variables you need to know?
Old 10-12-2007, 09:40 PM
eb02z06's Avatar
Bro-your going to have to put the car on a dyno and just keep adding timing until the gains are just not worth it-just watch torque and horsepower-2 degrees extra maybe worth 30 rwhp-add another 2 and it may only add another 15 on top of that-when that happens call it day and settle on the 2 you first added-it's always better to play safe. Keep the tune fat at 11.1-remember that if the meth fails your AFR will raise 1 point-just keep that in mind. I log IAT temps witht the meth so my nozzles are before the sensor-you can mess around with the computer to set IAT retard tables then.
Old 10-13-2007, 09:17 AM
ChevyChad's Avatar
Thanks man Guess its a case by case basis... I just wanted to know what everyone else was running so I could get a feel for the ballpark...
