What type of turbo is everybody runnin...
Old 10-16-2007, 08:10 PM
98SS2836's Avatar
Default What type of turbo is everybody runnin...
Just as the title states Im doing research Trying to get some ideas. Im want/going to try to build a 650-700+rwhp single turbo 346 looking for some turbo options. I think Im going to have to go with a T70 or somthing along those lines. Just fishing for some ideas
Old 10-16-2007, 08:18 PM
HUNTER02SS's Avatar
I am running Turbonetic's! alot of guy's are running Precision turbo's also.
Old 10-16-2007, 08:19 PM
30th t/a's Avatar
I have a feeling alot of people are going to vote T76GTS
Old 10-16-2007, 08:37 PM
HUNTER02SS's Avatar
I guess you were asking what size turbo for your hp goal/Something in the 76 range will get you there.
Old 10-16-2007, 08:54 PM
Mr.MartyStone's Avatar
S400...Hands down the best bang for the buck.
Marty
Old 10-16-2007, 09:38 PM
SS4Matt's Avatar
Marty
those are nice. my buddy picked one up for his mod motor cobra (mustang) those are freakin inexpensive!
i had a 76GTS, it's a really popular turbo...i now have one of the S400/borg warner cross breeds that Jose makes. ST80
Old 10-16-2007, 10:11 PM
markp03's Avatar
pt76gts...
talk to the guys at forcedinductions.com
i am sure they will recomenda 76
Old 10-16-2007, 10:35 PM
67Firebird455's Avatar
I recommend the PT76GTS also... I'm running the MP T70. Works okay for what I do, and it was inexpensive.
Old 10-16-2007, 11:02 PM
fash00's Avatar
tc76 from josh at kytp
fenix999's Avatar
master power t70 here as well and works surprisingly well for under 600rwhp range, havent seen what it does at higher than 8 psi but im sure as hell it rocks for being an inexpensive lil turbo. Either way im definitely jumping on the precision 76gts or Borg Warner S400 band wagon. From the numbers and performance ive seen, that seems to be where its at, good stuff!!! Might get the borg warner due to better price though, Hope this helps
Old 10-17-2007, 01:04 AM
Josh@KY-Turbo's Avatar
I have used several of the TC76MPS Turbonetics units with great results. It is a true 76mm turbo in a compact package. Everyone who has done a Turbo on an LS1 F-Body knows these engine bays are tight.
Old 10-17-2007, 07:36 AM
geeteego's Avatar
76GTS...it's a monster.
Old 10-17-2007, 07:55 AM
Willem @ Fuel Injection Concepts's Avatar
a GT42-76, or a 76GTS.. PM me for good pricing
I wouldn't put anything smaller on a 346... even though a 76 would MORE than suffice your 600 hp goal.. But with a 346 turning to 7000 rpm, you need a turbo with at least an "S" trim / GT42 hotside to keep power to redline.
Old 10-17-2007, 08:48 AM
LS1Tech Sponsor
hellbents10's Avatar
Borg Warner has the best unit for a good price. ETT wheels and better flowing housings. Jose offers them as S, ST, and SX units. New technology, not the old stuff every one else is using.
Old 10-17-2007, 10:25 AM
LS1TECH Sponsor
DrTurbo's Avatar
For quick spool, and those power #'s, the TC76 is hands down the best for that size engine. If you plan to upgrade later to a larger CI engine then the ST74,ST76 or 76GTS are great units. Also the GT42-76 or GT45F-76 are awesome units as well. A stock S400 is cheap, but spools like crap if compared to the units mentioned. Its a 74mm unit with a turbine wheel larger then a GT47 and has a 1.32A/R. Its all relative......
Old 10-17-2007, 12:58 PM
Spools like crap? You have seen the 3500 pound cutlass running 5.90's @ 119 in the 8th over on turbomustangs correct? With his stock S400 to boot.
Old 10-17-2007, 01:19 PM
PurEvl's Avatar
tc76 bob, gt70 would be pushing it a bit.
Old 10-17-2007, 01:28 PM
20lbbooster's Avatar
anyone have any input on the BW s375? Thats what I was looking at for my project...looking for 700-800whp
Old 10-17-2007, 01:43 PM
LS1TECH Sponsor
DrTurbo's Avatar
You mean 3400 lbs Cutlass with a built SBC 406 with transbrake, big convertor and the turbo was done. That is all great for a full blown race car....hehe. 99% of the people on here and most boards are building street cars and the other units will outspool it by a long shot and get you those times as well. No reason to cut yourself short to save a few bucks and ultimately be unhappy and end up swapping everything out later down the road for more added costs.
Old 10-17-2007, 01:46 PM
LS1TECH Sponsor
DrTurbo's Avatar
Go with an ST76 if your going BW, its built for YOUR application. Build the turbo around your setup, not the other way around.
Quick Reply: What type of turbo is everybody runnin...
