Car is finally done
Old 10-17-2007, 10:43 PM
chewy99ws6's Avatar
Default Car is finally done
Everything is done
This is where the turbo sits.
Just a few pipes
Turbo
The hole I cut out behind the bird for better airflow for the intercooler, my dremel died so I didn't get to finish cleaning it up.
Went alittle crazy with the RTV, but I know it won't leak.
driver side pipe
pass. side pipe
Old 10-17-2007, 10:44 PM
chewy99ws6's Avatar
Few more pics after I moved some wires and finished up
Next gauge is a wide-band
This weekend my buddy and I are going to make some vids, I will post them up as soon as I can. This thing is sick as hell on the street too. Can't wait to see what it dynos, just waiting on our next dyno day.
Old 10-17-2007, 10:55 PM
Restricted User
Smokin87TA's Avatar
congrats and looks like a great set up. Lets see some vids
Old 10-17-2007, 10:58 PM
chewy99ws6's Avatar
This weekend me and my buddy will make a few vids hopefully if his camera works. The car pulls like a SOB now, before the turbo I was making around 530HP N/A.
Old 10-17-2007, 11:19 PM
OreoLt1's Avatar
The near 90 deg. bend to the intake looks kind of restrictive with it being oval shaped but I may be wrong. Nice set up though and next in line for vids!!!
What else do you have in the motor to reach 530HP N/A?
Old 10-17-2007, 11:31 PM
Restricted User
Smokin87TA's Avatar
Are you running the ms4 cam with this turbo setup?
Old 10-17-2007, 11:34 PM
JMBLOWNWS6's Avatar
Why didnt you use GM exhaust gaskets?
Old 10-17-2007, 11:37 PM
chewy99ws6's Avatar
I thought so too, but that is what came with the kit, but it is really wide, kinda like the oval y-pipe on stock WS6's.
motor has MS4 cam, stage 3 P&P heads, every bolt-on you can think of, and I was running almost 12:1 CR, but I changed it out so I now run 9.5:1 CR, fully forged 346. I was suprised myslef when I made 530HP but hey I guess if you build them right you get really good numbers.
Old 10-17-2007, 11:38 PM
chewy99ws6's Avatar
for now yes, I am going to change it out for a higher LSA cam later on.
Old 10-17-2007, 11:39 PM
chewy99ws6's Avatar
I asked alot of my buddy's that run turbos and the company that I bought the kit from and they said use RTV instead and it won't leak, so far I haven't had a single problem with it.
Old 10-17-2007, 11:41 PM
JMBLOWNWS6's Avatar
Wow Ive never heard that before. But hey if it works it works
Old 10-17-2007, 11:42 PM
SSilverSSurfer's Avatar
i was thinking the same thing. so that RTV wont burn off?
Old 10-17-2007, 11:45 PM
JMBLOWNWS6's Avatar
I used the same RTV on my APS kit but I dont think you cant beat MLS gaskets. But if it works and saves you $ thats all that counts. But if it does leak that is alot of cleaning
Old 10-18-2007, 12:29 AM
chewy99ws6's Avatar
yea for now no leaks and I am running between 8-10 psi. I used alot of RTV to make sure it wouldn't leak. I was going to use MLS gaskets, but the company said they use RTV on all there kits they install and have never had a problem.
Old 10-18-2007, 08:32 AM
BLKWS6's Avatar
Looks good Wes.
Old 10-18-2007, 08:39 AM
RealQuick's Avatar
You need a litle more RTV on the header flanges... J/K
Looks good. Which kit is it?
Old 10-18-2007, 10:39 AM
chewy99ws6's Avatar
Thanks for all the comments guys, when I put the RTV on it looked good but I wasn't thinking it would spread out that much, oh well at least it doesn't leak. The kit is HP Performance, I got it with the T-70 turbo.
Old 10-18-2007, 11:15 AM
Websy21's Avatar
wow, turbo and the MS4, thats got to be the first. Looks good bro let us know how it all works out
Old 10-18-2007, 11:50 AM
chewy99ws6's Avatar
yea even with the MS4 it still puls like a SOB, I am changing cams just trying to get a custom I really like, want it in the 114 or 115Lsa range then the MS4 will be up for sale.
